Thereâs pretty much no chance it will be green looking unless you have it on 5000K. Two reasons, no AR glass lens to shift the tint and when mixing with 2700K it will bring it way down on BBL.
The light I built with 2700K+5000K LH351D ended up between 3400K and 3600K and was below BBL at all levels. This one is obviously adjustable but if you look along this line you will see why you dont have to worry about green:
With the lantern configuration and modest current, it would have been possible to have a small plug in connector inside the center tube in between the driver and the led PCB or right on the PCB to avoid soldering in that situation. That would allow disassembly and swapping the whole led PCB easily, although it will probably not happen very often⌠Maybe something to keep in mind for V2?
I would expect that the people who would ever like to swap MCPCBâs or shades, mostly coincide with people who have basic soldering skills, in that case a plug connection would cater just a few people. Me, knowing the relibility of a decent soldering connection, see a plug connection for over 1A as something that can go finicky over time.
I would expect that the people who would ever like to swap MCPCBâs or shades, mostly coincide with people who would like to swap P60 dropins. Which I believe is a much larger group.
Related thread, thereâs Lexelâs proposal for a similar type of connection for a similar but different use:
Iâd like to be placed on the list for two lanterns please.
Just curious, and I may have missed this somewhere in these 200+ pages, does anyone have any thoughts on how this lantern compares to the latest offerings from Fenix?
Also, am I correct in understanding that the power bank function discussed as a possible feature was not incorporated into this version of the lantern.
welcome to BLF Bake. I have not seen any comparisons to any Fenix lanterns yet. No, the power bank is not in this version, if thereâs a V2 I imagine it would be in that one.
Probably better than the Fenix offerings, if only because its likely commercially unviable to put in the massive amount of research, prototyping and refinement that DBSAR and the BLF team did into the LT1 over several years!
