Convoy L6... XHP70 Beast!
Benjy, DB Custom, and whoever else; whether it is done in this thread or a separate thread all it’s own… I really wish the discussion of Li Ion batteries would continue. Why you may ask……… because I would like to know once and for all what the truth of the matter actually is. :slight_smile:
Whether the person sharing info be a seasoned forum veteran, a newbie, or anywhere in between…… if they know their stuff; I’d like to hear it.
But I’d also like to be able to read references to back up what is said. That in itself would cut down drastically on opinion & BS that is shared. It would also galvanize credibility.
So for those that can back up what they say, I would really like to know the actual science, technology, & chemistry of the rechargeable lithium ion battery. Not just what I have heard or think I know……. :wink:
Update: After bypassing both springs with 20AWG silicone wire and improving the driver ground contact, R100 resistor modded L6 current draw: 6.94A with fresh liitokalas, ceiling bounce equivalent: 4,150lm.
Not sure how accurate my ceiling bounce method is but it was sort of calibrated with other ANSI flashlights, although much lower in output. Very pleased with the results, and the driver is cheap enough to replace if it ever burns. :smiley:
I will also be keeping my Sharpie ready to take notes :wink: :wink:
Let’s get it ON! :smiley: :+1:
I’m using an FET Zener modified driver in my black L6 and it’s doing right at 12A for a little over 7000 lumens. This is with the top tier XHP-70. It’ll get hot too, but most of the time the night air is enough to keep it real. These lights are just exceptional, another one of those that makes people want to liberate the light from your possession. :wink:
Hmmmm……… seems I missed that one. :person_facepalming:
KB, you have 36 of them. :open_mouth:
Could I please borrow that Yellow Sharpie, if the time ever comes to take notes that is? :wink:
Is it just the photographer in me or shouldn’t Kawi have much better lighting than that? :stuck_out_tongue:
Hey man that’s my 3300k-3500k?
LED lighting in my kitchen, I’m trying to get with the program here, don’t the colors just POP! :person_facepalming: :+1:
Lithium Ion battery discussion should certainly continue but we’ve spun out long enough for this thread haven’t we?
It would probably help more people if it were moved over to a thread dedicate to the topic like the Lithium-ion battery safety 101 thread.
I totally agree…. we have surely spun out enough. :+1:
Only reason I wrote what I did above was because one contestant suggested the debate take place here in this thread.
Personally, I just wish for the discussion to continue. And as far as I am concerned also, a dedicated thread would be the way to go to actually get to the real truth of the matter. :slight_smile:
That's great results! I further updated my black L6 mod to an SMO and a P2 1C, and now getting 6,700 @start, 6,250 @30 secs, and 149 kcd taken at 5m. I measured 11.45A tail (Clamp meter).
I knew I couldn't match your results because I think you did some machining for the MCPCB and could use 18 AWG wires, I think I recall. I'm still using a SinkPAD MCPCB.
Still, with Narsil ramping, TA's triple w/SIR800DP, and 62 uA parasitic drain, it's a nice setup. The SMO & P2 1C mod bumped it up by about 500 lumens, and from 132 to 149 kcd.
Couldn’t remember exactly what it did so I charged up the pair of Basen’s (4.21V) and ran it through the box… 20,700 on the meter for 7141.5 lumens (start). This is TK’s ramping firmware with an SIR800DP FET.
The cells were down to 3.85V when I pulled em to charge and it was still making 5745 lumens.
5745 out 3.85v what the , I been away for two long , what kinda light is this you speak of ?
Nice work Tom! I really want to experience an L6 with Narsil. Checked your PM inbox lately? :zipper_mouth_face:
It’s a modified Convoy L6, using a Zener modded FET driver.
Not working for the other versions apparently - Silver N2 3A :frowning:
I’ve bitten the bullet finally and ordered an L6. So I need some batteries. The BG Keeppower ones mentioned for the L6 aren’t shown in stock; will these fit?
http://www.ebay.co.uk/itm/GENUINE-KEEPPOWER-26650-IMR-5200mAh-20-45A-3-7v-Li-Mn-HIGH-DRAIN-BATTERY-MOD-LED-/201712337455?var=&hash=item74c5a9eb9a
Failing that is there anything else suitable from the same seller?
http://stores.ebay.co.uk/ECOLUXSHOP/26650-BATTERIES-/\_i.html?\_fsub=4656954013&\_sid=641059803&\_trksid=p4634.c0.m322
[quote=DB Custom]
You’re all right kirman, no harm no foul. :wink: Sometimes someone will come into the forum, perhaps with certain insider knowledge, perhaps not, and start pushing that information with zero background, which is misleading. It always pays to establish credibility first so people know or have a better idea if credibility is there. No matter to me, I’ve built far too many lights to be swayed by a newcomer with abrupt information. :D[/quote
Thanks DB Custom, I appreciate it . :slight_smile:
Thanks J-Dub74 :beer:
I’m fairly new here and I’ve found this forum to be second to none. I learn something new everyday, it’s always fun and just about everyone on here is decent and willing to help out.
Got an L6 last night! Can’t wait to try it out!
