I’m using a 20 x 1 mm tap. It’s too big for any tap wrench I have so I’m using a 10” crescent. I soldered the tube into a big ol’ brass nut so it could put it in the vise and used a combination of plastic tubes as a centering jig for the tap(the same ones used for the copper head core). Then desoldered it and started filing and sanding. I’m using the collar the same way you are Steve, to capture the wood at one end after I’ve brazed a stop collar to the tail end. I can’t braze one on the head end too or my nice wood will go up in smoke. There’s another short tube that fits into this one(at least it will when I’ve had my say) and that one has the 20 mm brass pill brazed to it that the collar threads onto. If you remember the first tube attempt had threads at both ends but that requiered reinforcement/thickening sleeves at both ends and I’d have to allow for the sleeves when reaming the wood tube. Since I need the short, inner tube to house the switch module anyway I decided to eliminate the internal threading and external collar. This will get rid of the void between the collars, allow me to pare down the tube, and subsequently reduce the overall thickness of the wood tube as well. If you follow all that I should fly you here so you can finish it for me.
One of my design guidelines is that whenever I use a manufactured part I don’t want it to look like what it was, especially if it shows like the bezel or this stop collar and had I left it six sided as it was it would have been both much heavier and too reminiscent of an L2.
The “big ol’ brass nut” is the other cap nut of the 3/4” compression fitting I’ve been using for some other parts, namely the bezel, bezel threads, and stop collar. Compared to their original forms and sizes witness protection should be so good. Most of the rest of the host is tube and sheet stock cut, rolled, thickened or thinned, and threaded, mostly by hand even though the drill press figures prominently. A good deal of time is spent staring at a pile of stuff trying to figure out how to put it together. The picture I drew early on is a guide to bounce ideas from and a visual aid but like Goose, it can’t talk to me. When I figure a section out I do as much with it as I can before I run out of gas or need to stop to allow some other section to catch up. Atm, the areas still a bit soft are the switch module and tail cap, I think most everything else is solid.
Rufus, When I get out your way, I want a lesson in HOW to keep a tap threading straight with a 10” crescent. :exclamation: If I tried that, there is no telling how the threads would come out but you can bet they wouldn’t look like yours!!
We have been adding some carbon fiber to a light or two here and I was glad to see how you & MRsDNF cover the ends on your wood pieces. That makes a nice look the way you did that.
Nice work… to say the very least. I sure have been enjoying these builds. :+1: THANK YOU!!! TL
Got some more done this evening. Here is the p60 pill fluxed and wired into a short section of tubing Then I spent some time. On the collar. I need to sand the O-ring side to 1.5mm from the O-ring seat. I used a washer as a guide. And ground it down close. And sanded it. The washer had tape on the other side as a shim. And I removed that and sanded it some more until I just began to sand the washer. After that I flipped it over, ground and sanded it down to even thickness at about 3.2 mm. Then I reamed the battery tube to fit the switch pill. It’s a snug press fit at this point. Here’s how it fits between the head and the tube. I also reamed the wood tube and sanded it some more. It’s ~26.2 mm now but with a wall thickness of 3 mm I think I can go down to 2.5 mm or less. Cutting the tube
Haven’t had the time to go through any of the build threads for awhile. Wow, really shaping up to be a gorgeous light. Lots of creativity, problem solving, and fine machining going on here. Hope I can braze like you someday.
I was home for just long enough to clamp my pull saw to the drill press table and spin the wood tube by the blade making 3 cuts. The first was at the tail to remove the bad part. The second was a few mm lower to get a piece for the tail cap, and the third at the other end to size it. Here again after that first cut. And how the cut looks. The blade is only about a half mm thick so I’ll be able to line up the grain pretty well when I assemble it. Here are all the cut pieces. Squaring things up
Squaring up some loose ends. This is the end of the copper core, as you can see it’s not quite square. Some sanding took care of that. The failed battery tube supplied a piece I will use for the tail cap. It’s close to the right size already but also isn’t quite square. All of this is under wood and epoxy and not visible but at least it’s now sanded square. Here again after filing and sanding the OD’s to match. Fritz had asked earlier whether brazing was complete between all the surfaces. Well, not quite. Since these bands were very tight in order to hold the seam shut it probably prevented even wicking of the silver solder. In any case the long seam is fully wetted and that’s the critical one. A few more bits of brass will be added to that little tail piece including a fresh piece of threaded copper. The one in the pic is from last year and not legal to use as part of this build so I only use it for test fitting. Oops II
Illegal bits used in your build? I’m glad you owned up as I would of twigged eventually, not.
Maybe we should be doing drug tests as well? Then maybe not, there may well be anyone left in the comp. :person_facepalming:
Another saw blade. At least this one is static. Just keep your fingers away from the gap. As usual loving your work RBD.
Bad news first. The MkII battery tube I fell afoul of poor logistics on my part and sufferered some kind of mischance(probably slipped in the shower). Here are it’s remains alongside the MkIII tube. I ran into a problem after brazing the stop collar on the tail end and poor MkII paid the ultimate price. MkIII has since been threaded and the the retaining bands removed. The next stop collar will instead be brazed to a short tube that slips over the battery tube before being brazed in place. That will prevent another unfortunate mischance. At the other end I used a carbide Dremel bit to cut the shelf out of the switch pill. Then I reamed it to one continuous ID and brazed a thin tube to fit inside. The switch will actually go in the small tube with contacts at either end and slide into the larger threaded piece. Tail stop
