Yeah, I have looked through the list for those as well but they just don’t have them.
My biggest complaint with Arrow is all the limits on the good items to 1000 minium quantity. They then dump those into the same sections as the items you can buy 1 at a time. Annoying to think you found the perfect item only to realize that you need to buy 1000 of them.
Here is my shopping cart at this point, I still need to go through all my driver components and see what I am short on. Think I am going to buy enough to build 25 or so TA drivers to test the waters.
Good catch, well the cheapest option after that is $1.30 each when buying 10 of them. MTN sells them for .95 cents each. So it works out to basically the same price as ordering from MTN and paying shipping, except that you can then add on more stuff from MTN……
Somehow I wandered off to LedSupply right now.
yeah no ledil.
Kahod (spelling?) is another I have only heard of. Never could find any suppliers in the states.
Well I’ve placed an order mostly for driver parts and a couple XPG3’s to try dedoming methods. Still have a week in case you guys find some other great deals there.
I already have way too many things in my cart but I might try to find the parts for a buck driver as well so I can play with that once I get it finished.
Yes, although I thought it was discovered the lower voltage only applies at a lower clock speed, which is set by fuses, which are not the fuses that we use. So I was under the impression it didn’t make any difference with how we flash them.
In any case I ended up ordering two of each, but thanks for confirming about the ‘R’
Do you have P/N's for the LDO's? I got ones without reverse polarity protection unfortunately, so if the ones you found have it, I'd look at ordering them.
