For runtimes there’s no need for accurate lumens measurements, just an simple ceiling bounce to set initial reference for 100% and then 1-minute interval reading for the first 10 then 5-minute interval for the rest. However without a computer logging light meter one has to sit there the entire runtime and manually enter the data to the chart which is really time consuming…
Man I literally came up with this idea a minute ago. If you don’t have a data logger, why not place a clock next to a lux meter, and record a video with a smartphone? No more baby sitting…
Edit: nevermind the clock; the video has built in timer.
Phenomenal light so far. Thanks for the review!
Guess the only reason for not using the PVC lightbox is heat issues, but could keep a fan goin on the light. For the test, recording of the readings. Smartphone or iPad might do the trick - haven't done much in video recording off those devices, but could check it out.
fwiw I put the 9k X7 in the tube for runtime tests. Tiny fan kept everything just fine, but I imagine even without the fan wouldn’t be an issue.
I carve out a few hours and chill next to the light while I listen to a podcast or something like that and record temp and lux via timed alerts.
Yikes! If I tested all modes, that's 228 + 32 + 18 + 10 + 8 + 98*24 hours, or 2,648 hours.
Ok, without moon mode it's only : 296 hours, or 12 1/3 days - not bad . I'd only lose 8 days of income, several $K there, (I only get paid for hours worked), and no sleep of course .
Ok - maybe only turbo... Just one full work day or long evening...
Might have to figure a way to work @home while this goes on... Hhhmmm, or be able to bring everything into work and watch while typing away... Might be do-able .
[quote=It’s funny to me how long and complicated they made their serial numbers though.[/quote]
There are probably expecting to sell A LOT of these lights.
Now we wait…….for the price.
Grtz
Nico
i think this light can very well compete with the acebeam k60 as far as performance. 5000 lumens and 132kcd is respectable. but i agree with what dbcustom said…its pretty much last years numbers. I would have liked to see 6000 or more lumens. considering the size of the heatsink, i would have expected longer runtime than 5 minutes on turbo. most lights can only run turbo for 2-3 minutes, but their head and heatsink is nowhere as large as this mt07. my modded tn36ut can run at 8000 lumens for 5 minutes, and its alot smaller.
i’m not sure if haikelite will be coming out with a smo reflector for this light, but if not, shaving the dome will be a good idea for a light like this. vinh said shaving the dome off of xhp70 on a op reflector makes the beam perfect and completely eliminates the donut hole effect. at least this is what happened with the k60.
i like the fact the light is under $100 and great value for what you get. the double switch and ui is great. and the easy to mod makes it even better.
but the thing i would like changed is the heatsink or the handle. im guessing its too late now to change the design up drastically. but i think the light should have been 1 inch shorter at the head. it seems very top heavy. and since i think the diameter of the reflector matters more than the depth for throw, it would have been very minimal decrease in the throw department. this way, the user can hold the light by the handle and the smooth surface where the switches are…instead of holding the light by the handle and to the heatsink.
ps. the price has been listed….its $95
Very nice review of a very nicelight!
(nice they engraved Tom E on it, can we order them with a custom engraving too Lol joking)
Just turbo would be nice. Not even the whole run would be necessary. It would just be good to be able to see how far they drop it down in order to achieve 8 Hours.
That has to be a ridiculously massive drop to squeeze out that much time.
For the runtimes, I'm getting curious now. I'll ask them as well, but still would like to do an independent test.
For the S/N, I was trying to figure it out. After the year it's a letter, 3 digits, letter... repeating... and the #'s are 0002, 0003, 0004, and the letters are: H-A-I-K-L. Interesting... There were a couple more review units sent out. I've been pm'ing with bluzie and he's getting the MT03, but got messed up in customs so still another couple weeks.
It might have extra data in it like a vin.
Added a turbo mode discharge curve in the OP. About 7 minutes in, there's a big drop, then the rest is a slow drop off
Thank you Tom, very much appreciated.
Couple more Q’s if that’s okay:
Can you bump it back up into turbo after the stepdown?
Does it always drop at the ~7 minute mark after activating turbo or is there thermal regulation?
The bump up should work, but not sure exactly how - probably just a click on the mode change button but whether it goes into turbo or back down to lowest mode is the question. Cells are at 2.9V now and still getting the BLUE LED blinking, so according to the specs, that's at 9% or above - not sure if that's right.
Earlier I did a 6 minute test and it didn't drop down. In the run, it dropped at the 7 minute mark exactly. No time now to test - got an appt for the car, then to work. Think the best test to do would be run it again til it drops down, then turn OFF, back ON turbo, and being that it's hot, see if it drops at 7 minutes again (timed) or earlier (thermal sensor).
I gotta do some R&D on charting tools - Excel is very frustrating to control... I got external temperatures to plot too.
Thanks for the info.
Yeah Excel can be a pain to get it to do what you want.
To get the axis right I believe in the axis format I changed to dates then did some minor tweaks to get proper spacing and numbers.
Dual axis for outputs and temps is more complicated and very fickle. Should be some helpful vids on YouTube though.
I’m a bit puzzled here. The light drops down to 2000 lumens after 30 minutes, even though this light has got huge heat sinking. Olight X7/Thrunite TN36-UT can produce 4000+ lumens continuously with much less mass…
Well the Mt07 does about 4800lm for 7 minutes and drops to a little over 2k lm.
The X7 does about 5500lm for about 10 minutes before dropping to a little under 2k lm due to thermal regulation.
Ambient temps and general settings can be a factor. I suspect the MT07 is a fair bit cooler at the time of the drop and the drop itself may be timed.
Where did you see the Olight X7 running 4000+ lumens continuously? If its not true, why would you make this claim?
What about the TN36-UT running 4000+ lumens continuously? Where is this tested, documented, claimed, proved?
Continuously is a bold statement without a time frame - minutes, hours, days, til the cells drain?
