On the P30, newly arrived just this evening, I measure…
With a Sony VTC6 at 4.18V…
0.005A for 1.4145 lumens
0.12A for 64.377
0.47A for 253.575
1.08A for 506.46
3.06A for 1048.8
Lux is 115.25Kcd for 678.97M throw.
Very nice smallish light right out of the box. Sort of a refined C8, slightly larger head diameter and slightly shorter overall length with a protruding tail switch lock-out for on/off and a side e-switch for modes. The C8’s bezel just about fits inside the bezel on the P30, the P30 has that new style very thin bezel coverage over the reflector such that the reflector is very large in there, looking at the C8 and the P30 side by side, into the reflector, it’s a very obvious difference. The 1/2” or so that it’s shorter also appears substantial. Very punchy little light in completely stock trim.
I haven’t checked to see if it’s glued but am pretty sure it is…
Edit: FWIW… I don’t care for protruding rubber boots on a tail clicky, so I swapped the tail cap with the one from my SRT6 Night Officer and they both work perfectly, color matches, looks like it was made to work this way. Now my P30 has wings around the rubber boot for protection.
Does anyone have this and a SF 6P on hand to compare their body lengths. The 6P body is just long enough for me to hold comfortably during extended use. The body on the P30 looks a bit short to me. Curling the little finger or both the ring and little finger around the neck will not be a comfortable grip for me. Thanks.
Ok, the more I look at this the more I have to wonder, are they all like this one or is mine sub-par? What I’m talking about is the reflector. The hot spot is “soft”, not well defined. Looking into the reflector this shows as a soft reflection of the HI emitter. There are a LOT of lines under the mirror finish and it’s just not a clean smooth mirrored reflector…. so is this by design or is my sample a bad one?
Edit: I mean, seriously, this is a Nitecore flashlight. They advertise this…
Do y’all see a nice clear mirror finish in the above picture? Yeah? So do I!
Now what do you see?
This image doesn’t have my watermark on it because it’s a JPEG straight out of my Canon 7D MkII with EF-S 60mm Macro f/2.8 lens. No processing by me, no nothing. So why is my lens looking like someone tried to clean it with a cotton shirt when they advertise this high tech computer optimized perfection?
And just to show it close up at a similar angle as their advertising…
Oh and how’s the beam profile. Dim spill with an intense hotspot, so when looking into the distance, you see the spot, and around it a large dark doughnut, and then around that a dim spill doughnut? Or bright spill with a bright spot in the center? Thanks.
Astonishing that this can throw still further, if the reflector could be further polished to a shine as you suggest. Hey maybe Nitecore does put more effort into reflector design than everyone else.
I’m very curious to know if your reflecter is a lemon also. If not, I wonder why nitecore chose to do that? Man if that light is moddable, putting a dd xpg2 should get you the same lumens but should hit 180 kcd?
If I can get some feedback from some other folks getting one of these I’ll make a decision on whether or not to crack it open and hand polish the reflector. From there some experimentation would show me what an end result might be.
I bought the P30 from Battery Junction. The address they list seems to be bogus, I know someone that lives in the city they’re in and after a few drive by’s he’s convinced the address is a maintenance building for a furniture plant that burned some years ago. He’s seen no signs of life around the place in the 3 or 4 drive-by’s he’s done. That makes me wonder if they’d warranty the light or not.
If other’s get this light and the reflector is beautimous, I’ll give them a call and see what they have to say…
DB, perhaps try contacting Nitecorestore.com and even Andrew and Amanda. If it’s a widespread defect, I hope they be honest about it and pull their stock.
I think the reflecter was meant to be this way for some reason. In the picture where it shows the light mounted on the rifle, the reflecter looks appears to look the same as yours
I sent a few pics to DB of the P30 reflector, I didn’t know how to post pics on this forum.
Anyway, my light came from Andrew-Amanda a couple of days ago.
