Itsonlyme - thanks for your suggestion.
My limited experimentation with reflectors has left me with blurred edges to the shadows, even though it throws more light forward. It’s as if the light is coming from a much broader source. The pin prick of light gives the crispest beam.
I wonder if some combination of lenses might work, but that’s beyond my ken!
Where are you in the UK?
As you have mentioned, you need a point source for the light. A reflector or lens won’t help.
Best choice is probably something like a CREE XPL HI LED run at 2-3 amps mounted on a heatsink and attached to a power supply to allow it to be plugged into an outlet. Depending on how many amps you run it at, you could easily get 500-1000 lumens.
I’m in Newport, South Wales. Not the nice one
I see no problem taking a flashlight with a really short reflector and replace it with a spacer.
Or one to replace a lens with glass.
This one with the lens or a glass should be OK.
http://www.gearbest.com/led-flashlights/pp_394637.html?
You can drive the light with a buck driver like this set to 4V, or replace the driver with this set to 1.6A for 500Lumens
Thanks Firelight2. That’s pretty much what I’ve gleaned from scouring the RS catalogue. I suppose I was hoping for some existing ready made solution that would fit the bill.
The lighting feature is to be mounted externally on a nature reserve visitors centre wall. It’ll be eventually wired up by a registered electrician, but I’m wary of dabbling with leds/electronics that are way out of my experience for something that’s going to be in the public realm.
Is there anyone you could recommend who could provide/build what I need?
Thanks in advance.
Thanks Lexel. Those links are interesting. I’ve wondered if adapting torches might be a possible solution. I’d probably be driving 5 or 6 of these in total, so am assuming that I can just do the maths and get a driver that delivers enough power to each for my needs.
Weatherproofing is my other concern, but I’ve seen some ip67 cases that may work.
There are two options for tiny and bright:
1) Cree XP-E2 ‘Torch’
When driven at 2.2A (it can not be driven much higher) and well heatsinked, it puts out 500 lumen when dedomed. The led with dome is the same size as the led in your picture above, but it can be dedomed what makes it an even tinier source for even crisper shadows.
2) Osram Oslon Black Flat
Driven at 3.5A it puts out 700 lumen. The led is already without dome, exact the same die size as the ‘Torch’
Leds do not come tinier at the moment. There is the Cree XP-C that is smaller but is comes nowhere near 500 lumen.
Now you need soneone to make you the light, I have no time for a while, but perhaps someone in the UK?
Nice one djozz.
I’m so happy to have found this forum and be getting some solid leads. This has been doing my head in!
500 or 700 lumen would be the business. I’ll investigate. Thanks.
I see no problem in sawing off the back of a torch solder wires on the driver and fill it with hot glue.
The light color should be more warm, cold or neutral?
Another solution might seem a little odd but should work well.
http://www.kaidomain.com/p/S024418.Cree-XM-L-T6-Neutral-White-5000K-5500K-with-18mm-x-18mm-Aluminum-Base
Or
XPL will be a little sharper
http://www.kaidomain.com/p/S024472.Cree-XP-L-HI-V2-Neutral-White-4500K-LED-Emitter-with-KDLIGHT-3535-20-20mm-x-1_5mm-DTP-Copper-MCPCB
Take a proper heatsink, use thermal glue to get the star on it.
Use glue to seal off the 4 sides of the LED and the solder pads.
This one should be big enough.
Use the Buck driver set to 1.5A per emitter, you can wire all emitters in series if your power supply provide >4V per LED.
Dedomed Cree XPG2 or XPE2 might be an option for very small emitters, but not something for a beginner, need to reflow on DTP for the XPE2
If you cen get dedomed Emitters you need to seal em with polyurethane clear coat.
I forgot to mention that to get the mentioned performance, both leds need soldered onto a so-called DTP ledboard, which gives ultimate heatsinking. Make sure that your builder uses them! The Oslon officially does not fit the most used XP-type boards but you can succesfully solder them on there anyway.
Been sitting here casting shadows of my hand on the ceiling…
You need an unobstructed light source. No lens no reflector to get a crisp shadow at that short 10-15cm distance.
What we call a zoomie flashlight comes close but not at the short distance. I now tried a flashlight with no lens and no reflector and it casts a nice circle of light and has very crisp shadows of my hand on the ceiling, closer and further away than your requirements. You should be able to get it close to just the size of the steel plate.
Perhaps take the glass and reflector out of the 10W flood and see what happens. I have a couple 12V 10W in warm white here if you need me to give a try. No cool white on AC current here at home.
I think the fuzzy shadow is from the glass reflecting back on the reflector and mimicking multiple light sources. If it works and you need brighter go with 20W. These lights are over rated so even a 20W is only about 13W actual.
Aha! I have someone doing exactly what I seem to spend hours of my life doing! I spend a huge amount of time shining lights through my peg basket. Flashlights with no lenses definitely give the right effect.
I did pretty much dismantle the 10 w flood to see what was making it blurred. I think it’s just the width of the array itself (is that the right word?). It’s not in front of me now but I think it’s about 10 mm squared or so. That’s just too broad at the distances I’m needing.
The XPL HI emitter is about 2x2mm
To get 500 lumens you need about half the max current of it driving at 5W
Just look at 4500K color so the light is a decent daylight or warmwhite ones
I am pretty sure it will be well enough, no need to go for an 1x1mm XPE2 overdriven
If it helps anyone: this reflector-less kind of light is commonly called a “mule”. I’d have my C8 like that, but without the reflector there’s nothing holding up the lens, and I’m not a fan of such blatantly-vulnerable hardware :confounded:
quick test
dedomed XPG2
15cm from LED to 10mm hexagon plate
Beam distance to my ceiling 1.7m
XPG2
20cm from LED to 10mm hexagon plate
Test with XPL HI
Test with XPL HD
with reflector only the spill is useable
Test with XHP35 HI
XPG2 dedomed and XHP35 HI
the XPL and XPL HI are in the middle of that sizes
I would just buy a BLF A6 for $27 and unscrew the head like this:
It has 7 brightness-es to choose from up to about 1600 lumen.
Thanks Lexel, I really appreciate your help. That sounds good.
Is that easy enough for a novice to put together do you think, or should I find someone experienced to put it together for me?
Edit…
I’ve just noticed the other posts and the photos. Thanks for all the effort, that’s fantastic.
Cheers everyone else too. Lots of stuff to consider.
I’m not weird… Honestly, I’m not. :cowboy_hat_face:
Have some lights here in various form and after reading the posts I was curious of the how or why shadows were blurry or crisp edges.
I always want to know why.
Also the light I have at the moment without lens or reflector is using a Cree XP-L HI emitter.
You are trying to accomplish what I would not necessarily want from a flashlight. Too white causes reflection back in your eyes and washes out the color. Also harsh shadows make it hard to see more. Warmer colored light or what we call high CRI emitters will offer better visual effects to bright flashlights by blending the shadows and reducing reflection back at you. The Sun in your pocket.
so according to my tests the XPG2 dedomed does get the best results folowed by the XPL HI
I added a few more results a few post above this one
but you see the 10mm Heyagons from the metal plate even with a larger LED like XHP35 HI
The dome on the XPL LED affects the sharp edges a lot
finally the XHP70 fails on showing the shape of the 10mm hexagons
Test with XHP70 sliced dome
