Are you gessing that they are or are you sure? I haven't actually tried them yet, they're still charging. But why so negative :P? If three 18650 fits then three 26650 should, they even fit each others chargers...
Do not try neodymium disc type magnets. They might short out at the positive end, should you knock the light hard while it is switched on. It's not supposed to, coz the internal is anodized. But there might be negative contacts at the front and you know Murphy's law always kicks in. 3 x 26650 gives a lot of boom, these are not IMRs. Be careful when using them HB201 and jurdiciously monitor the voltages. Do not use for long periods or leave it unattended.
I believe he is going by the manual, which is probably not properly translated. Theoretically, the voltages of 3 x 18650 will be the same as 3 x 26650.
Check out mitro's battery tests, upper left hand search field, it's pretty good. Each king kong can do 10A. So basically each cell can supply 30 watts of power. 3 of them have a 90W potential. Even 2 x King Kongs is a piece of cake for the light.
IMRs are inherently safer. Google LiMn (IMRs) and Lithium Cobalt. BTW, i mentioned safer, not safe. :) The safest is LiFePO4, but that is 3.2V and pretty much lower in capacity. Do a youtube search on everything, you can whack LiFePO4 around like crazy, burn it with a 1300C blow torch, and it'd be quite a while before it explodes. :) Correction, it does not even explode.
Safest is just get 3 x 18650 protected high-quality cells like XTAR 2600/3100 or if you can afford it AW/Redilast and be done with it. Still loads of runtime.
I believe that he's referring to the safer chemistry of the IMR cells. Magnets shift, a short occurs, and you have a pipe-bomb with at least 1/3 more energy than the one that destroyed a coffee maker, window, and human hand.
I know those cells, I have many original a123 3.3v lifepo and others as I am RC car racer :) But king kongs are new to me, I bought them and their resistance is as imr, capacity higher. Safety...is not that important for me ;)
Safety in RC is a bit different from flashlights. RC you can blow up the bugger with enough smoke as if you lit up a 100 shot fireworks cake and no issue, coz it is outdoors and not in your hand. But a flashlight is often in your hands, plus it is enclosed tightly plus extremely securely (a good tube of 6061-T6 is tougher than you think).
