Yeah i agree, LVP much more crucial for me too.
As far as i understand with 1.2 i loose the ability to add a led to the e-switch to have it show me voltage readouts. But i still could add a led there just as a locator, did i get that right?
Also i could flash the 1.2 with 1.5 when it is ready if it is not by the time of sending out batch 3, correct?
My order should be something like 30mm, Narsil 1.2 with LVP, and 2S LDO if i got everything right.
Btw, can the tactical 100% blast on the rear switch be removed? i would prefer to use the clicky just as lockout
Your right, you canāt use the indicator output with v1.2, but you donāt really need it. When you triple click, the main led will blink out your voltage. Plus you can use the power output pad to make the side switch light up when the tail switch is on (locator).
If you know how to flash it, then sure, you could upgrade to version 1.5 when it is ready. I donāt know how to do that.
The tactical rear switch is written in the code so it canāt be turned off. It would require a reflash to get rid of it. I have the tactical on my L6, but find its not as practical as I thought it would be. Itās so easy to click on and off with the side switch that I find myself not wanting the tactical option. This second driver Iām ordering will be programmed to do nothing when the rear switch is activated. I will know the rear switch is on because I plan to have the side switch light up on my new light as well.
2B seems like the best option to me.
Btw, in group mode what are the spacings of the different levels?
And is there a posibility to choose custom output levels for a certain group?
Edit:
Oh, and will there be a version with both LVP and Temp protection for 2S in the near future ? Is it a hardware or software limitation at the moment?
So if i get the 1.2 version driver now, and later Tom releases NarsilM, i could flash NarsilM and get the Temp protection too, is that correct?
Or some hardware modding would be required too, to get both LVP and Temp protesction with NarsilM?
To be more precise,
i was asking if i now get the 1.2 2S Narsil driver with LVP on PIN 7 and then Tomās NarsilM comes out with LVP set on PIN7, i flash it on the driver.
Will i then have both at same time 2S LVP + Temp Protection ?
Or it still will be a choice between 2S LVP or Temp Protection?
What do you guys use to inspect them, a magnifying glass?
Iāve found that my phone camera set to 5x zoom and a small flashlight makes for a very handy video microscope kind of thing.
If I had to do a lot of drivers I would get a tiny turntable so I could rotate each driver while holding the camera and light fairly steady. Itās so much easier on my eyes. :+1:
