so did the Bistro drivers I assembled so far
and the Narsil v1.4
I had 2 drivers where in 2S operation one AMC7135 had this parasitic drain issue when the driver is in sleep mode
they are oficially not build for 8.4V
still waiting on boards from Oshpark that I have ordered later as more were requested than originaly planned
I printed the shiping addresses with information which drivers and export declaration
then used residue tape to fix the drivers where they belong
also wrote on the tape the drivers specs
Are you sure it’s the chips that are bad? Maybe there’s a problem occurring in the first flashing process that makes the chip not able to be re-flashed?
so a lot orders are shipped
the first 2 or 3 ones were done shipping today, but then the rest will picked up Tuesday,
because the driver came who picks up the stuff from that post office came when I did the first envelops and filled out stuff for the othen ones
tracking numbers can be seen here
date of today 03. June 2017
and your RR tracking number
the tracking most likely will start when they get picked up Tuesday
Ok, sorry to be a bother. I haven’t followed every post here. I was trying to figure out if it’s possible I could get a driver for the Courui D01. I looked at the OP, but I’m not sure I’m understanding all the options and how they add up together. I guess it would be the 38.5mm driver, so that costs a bit extra for being a larger size. I want NarsilM if you’ve got it worked out, or whatever is the latest working version. I will do temp calibration myself. I want the standard amount of 7135’s on board. And it will be used with the normal 1S3P set-up of the Courui, with a ~3V LED, so I don’t need LDO and the LVP should be set for 1S operation with the standard values. I also don’t need a spring provided because I have springs of my own.
So, first, can I order one, or is it too late? Secondly, if it’s okay to order, what is the total price with shipping to the US? I tried to calculate it myself, but I’m not sure if I got it right. Please check and let me know.
Oh, just looked again at post #2 and it appears that three 38.5mm drivers have already been ordered. I don’t need 3x of those myself. If any more get made, I’d like to get one.
