I was curious about one thing. I know the mcpcb has 2 screws holding it down to the shelf for heat transfer, but does the bezel and lens also push down on the reflector like on most flashlights?
(Giving better and more even heat transfer between the mcpcb and shelf)
There might be a slight, very slight; difference. Tom E did some testing on this but I can’t find it right now. If I do I will post a link to it. But IIRC, the difference was very slight.
Another thing to consider is all boobs are not created equal. Some like tiny boobs while others prefer large… some even solder giant boobs on their cells. I think this boils down to personal preference or either that is just how theirs turned out.
Either way…. I’m sure your boobs will be more than adequate.
I’ll try to find a link to Tom’s post on batteries & post the link.
Button tops are typically spot welded (I believe), and the metal - not sure how good the conductivity, so totally up to the mysterious 3rd party that installs the button tops. Solder, though supposed not great conductivity, is solid to the battery top. I would think/guess solder boobs will always do better, and my testing seems to prove that out compared to the button tops I have, and tested.
For durability, reliability, button tops win out every time - solder is soft, subject to going flat over time (not drooping), plus the metal could be rubbing off on the brass contact ring over time - bad if it fragments, but not sure bout that. I think I've seen this occurring though - probably best if the brass ring is polished smooth.
To fix this, could solder brass buttons to the top of the batteries. I've done this several times as well. I haven't had one fail yet, but never used them in an SRK style light (contact ring). I'd be concerned about the quality of the solder bond, if the brass button is at risk of falling off over time. Probably dependent on how well the solder job is done - clean surfaced, good amt of flux, etc. If you do use brass buttons, I'd say the contact surface should be sanded down on the edges so there's smooth contact - most of these buttons come with sharp edges. Brass will hold up better than solder for sure, but brass is relatively soft compared to steel for example, but it would be brass to brass contact so maybe that's good.
I dunno if all these concerns are warranted - I got limited long term experience with these usages.
I refer you to kramer5150’s avatar from July 2015:
So… you’re saying the softness of boobs might make them lose their zing after menOhmpause?
Let’s not even start on the puns related to electrical conductivity being measured in siemens.
In practical terms though, solder blobs are relatively easy to rejuvenate when necessary. Just re-melt it, maybe add a little solder, or file down the tip a bit (ouch), and it should be good as new. I’ve had to do this occasionally on blobbed drivers when the contact surface gets dirty. It may also be a good idea to clean the contact ring on a SRK-style light once in a while.
This kind of thing isn’t limited to just solder though. I also have to clean the battery (steel? zinc? nickel?) and contact post (aluminum) on L3 L10 lights periodically, since it gets thoroughly blackened during use.
I’m glad the Q8 has a thick contact ring, since it’s going to get worn over time regardless of what the battery tops are made of. With a thin ring like a regular PCB copper pour, wear is visible after just one use… but this thick brass ring will likely last pretty much forever.
I would not know, i rarely get to know one from the other sex good enough for me to ask for permission to examine her features that close.
And i am not the kind that jump at every little chance he get, that actually make me suspicious and work like a bucket of ice-water on me.
I think, flats tops will work with it now as is… sparkyDK.
EDIT: If they are of proper length. :+1:
………… FINAL EDIT: … Sanyo GA flat tops will work because they are raised flattops.
Q 30 flat tops or any cell with flat tops like them… WILL NOT work.
My apologies for the initial incorrect informatio I gave. :person_facepalming:
I’ve been watching this on and off since the beginning and it looks like it’s finally coming together into a really impressive light, well done and thanks to everyone involved in the design. Please put me down for one.
Do we have any rough timeframe on shipping the final version yet? Once approved are they ready to start manufacturing?
