you would loose the temperature calibration
I wrote on many driver labels the value that shows the temp offset like –12 or +3
with the new NarsilM you can copy the firmware and do the temp set over the UI, while the temp blinks wont be accurate as its not matching the offset
the temp calibration and preset of the temp protection on NarsilM is optional, while it was needed on v1.4
Thank you. I think I may give NarsilM a try if I decide the one light really would be better if the tailcap switch did not turn the light on when clicked to power up. In the meantime I should also get things together and try reprogramming one of the ATtiny13 MCU’s I have sitting around; practice on something that does not matter so much.
I am interested in 2 drivers. Both 21mm NarsilM and 2 springs included in the envelope. I should order the larger spring? For Skilhunt h02 headlamp. Shipped to USA.
I would like to try them just as they are described in the google reference:
No thermal step-down, I want to give the timed step-down a try.
Hi Lexel!
Can you send unsoldered driver kit? One board and the parts in an envelope. If I want a Convoy L6 TA driver with NarsilM and 2S LVP How much does it cost unsoldered to send it to Europe Hungary? Or how much If I need two of these like this?
Thank you!
I forgot to tell that I have many 7135s and some FETs also left from 17mm single cell TA builds. So I don’t need them. And I have springs and cables too.
Ahh, got it. I thought if the bottom 7135s were on a third channel it would require an adjustment to the tables in the firmware. If that’s not the case, I’m definitely going to be in for a few more!
I ordered today 100 FETs and parts for 45 Bistro HD, 10 TA Bistro and 45 Narsil drivers from Digikey and Mouser
Updating the excel sheet atm
OP Updated:
Price 0.5$ reduced due to lower parts costs
springs can be soldered, but stiff long spring adds shipping
2x0.75mm² silicone cable can be presoldered for 0.25$ per inch
also soldered short or large long spring plus soldered wires adds shipping cost
This time even better FET SIR404 from Mouser as when 100 ordered they are minimal more expensive as SIR800s from Digikey
are you talking about
FET+1*7135 2 Channel
or FET+1+1*7135 3 Channel
