This batch is finished
next batch here
also for the Q8 launch with SIR404s upgraded
I am atm going to get a Q8 board design due to the different PCB diameter and screw holes
v1.5 Prototyp board tested successfully
I will also give the option this time to sell kits, containing all parts and boards, with flashed MCUs for Bistro and NarsilM
This saves 0.7$ shipping and is cheaper, still NarsilMs startup, over temp protection and LVP can be configured but not calibrated
Bistro-HD OTSM can be ordered this time, it needs special parts
OTSM works perfectly with lighted tailcap and hot light no more OTC timing issues
If you want fully assembled and tested drivers reply here
Flashed and thermal calibrated MCUs are included.
This batch will be reflow soldered, got enough expirience in 2. and 3. batch
Availiable options:
there are different sizes availiable 15, 17, 20, 21 and 22mm
those are cheap on the PCBs from Oshpark so I may end up with some unused boards
30mm, 38.5mm and 46mm SRK are possible as well, but add costs depending on size
Information about this driver series here
This time will be using the SIR404 FET as there will be likely a lot Q8 drivers
You can choose a custom number of 7135 less than the maximum
can be equipped with Attiny 25(V)
running TA Bistro, Bistro HD or Bistro OTSM
or
Attiny 85 running Narsil v1.4 or NarsilM with latest version with fixed bugs
Narsil manual, a lot options to configure this one
http://www.metronixlaser.de/bilder/flashlight/Narsil_Triple_Manual_v1-3.pdf
NarsilM availiable for this batch NarsilM - configurable e-switch firmware for Multi channels, v1.3
Drivers will be fully tested
NarsilM driver can be thermal calibrated as well
you can choose the temperature for stepdown, but change it later in User Settings
the time for stepdowns depends on the lights size/heat, a pocket rocket off a 14500 high drain will need a shorter time than a Convoy L6
standard will be 60°C
standard stepdown time 45s
temp calibration with heat gun
there are 2 main options for 2S NarsilM for lights like Convoy L6
NarsilM it is possible to choose between indicator pin and LVP the whole settings are reduced for an easier handling for the Q8, new version a lot improvement and bugfixes
For 2S lights that use only a sideswitch or you dont lock out the light a LDO is needed,
the zener mod has a very high parasitic drain so this is only suitable for Bistro drivers
2S LDO is availiable for 17, 21, 22, 26, 30 and 46mm
2S Zener Mod is availiable on all sizes
Piggyback LDO on other sizes possible adds 1.5$
efficiency advantage over Fet+7135*1
this is just an example, keep in mind that triple hotrods get more gain than a single emitter light
Connections:
Springs:
for 17mm Board will be phosphor bronze in 2 lenghs
for 15mm board the short spring fits (the long upside down but risky)
All drivers come without soldered springs, to stay below 10mm envelope thickness which is 2.2€ cheaper to ship
For larger boards those springs are good
http://www.kaidomain.com/p/S024318.DIY-Gold-Plated-Battery-Driver-Contact-Support-Springs-8mm-D-x9_5mm-H-for-Flashlights-5-pcs
recommended with lead solder paste, but can do lead free if requested
Prices:
15-22mm
12.5$ TA Bistro Attiny25
14$ Bistro HD OTSM Attiny25V
NarsilM Attiny85
13$ flashed standard Narsil settings 60°C uncalibrated, SD=2.8V, PO=(2B),
14.5$ with calibrated 1S or 2S LVP / temp calibration and max temperature preset, this version has no indicator LED
Narsil v1.4 might be used when timed plus thermal stapdown in a small hotrod light is wanted, but NarsilM has a lot improvement
per loose spring add 0.3$
springs can be soldered, but stiff long spring adds shipping
2x0.75mm² silicone cable can be presoldered for 0.25$ per inch
also soldered short or large long spring plus soldered wires adds shipping cost
30mm add 1.5$
38.5mm add 2.85$ if 3 boards come together
46mm add 4.5$ if 3 boards come together
Zener mod add 0.5$
LDO 1.2$ 21mm and bigger only
LDO 17mm add 3$ more expensive part
Bistro or Narsil customized modespacing adds 1-2$ depending how many groups you want changed
or you suply a hex add 0.5$
Bistro 2S Zener mod needs to be adjusted with a customized voltage divider to the MCU add 1.2$
SRK Size with more than 8 AMC7135 Bank add 1$ for all 16 AMCs
2$ envelope shipping worldwide
Tracking + insurance up to 25€ adds 3$
Soldered long phosphor bronze springs are possible, but it adds 2.5$ shipping costs
Insurance up to 100€ and tracking adds 5$
Insurance above 100€ and tracking adds 7$
1€ Germany
adds 2,5€ for tracking + insurance up to 25€
