Ahh, got it. I thought if the bottom 7135s were on a third channel it would require an adjustment to the tables in the firmware. If that’s not the case, I’m definitely going to be in for a few more!
I ordered today 100 FETs and parts for 45 Bistro HD, 10 TA Bistro and 45 Narsil drivers from Digikey and Mouser
Updating the excel sheet atm
OP Updated:
Price 0.5$ reduced due to lower parts costs
springs can be soldered, but stiff long spring adds shipping
2x0.75mm² silicone cable can be presoldered for 0.25$ per inch
also soldered short or large long spring plus soldered wires adds shipping cost
This time even better FET SIR404 from Mouser as when 100 ordered they are minimal more expensive as SIR800s from Digikey
are you talking about
FET+1*7135 2 Channel
or FET+1+1*7135 3 Channel
I appreciate your patience with me as I start to learn the firmware side of modding. It would be FET+1, 2 channel. I’m trying to achieve single sided drivers this go around.
Hi Lexel! It looks like in your latest spreadsheet you have me down for a 17mm driver, but I don’t need one of those. I’m just looking for a Courui D01 driver, if someone else will order the third one! You may need to clarify with mattlward. He said how he would like to use a Courui D01 driver, but didn’t specify that he wants to order one from you. I think he meant to say he did though. So, just need one more if so to make a three-piece order from OSHPark.
(1) 17mm 1S Bistro HD OTSM, short spring, 2x 1” wires
(1) 17mm 1S TA Bistro, short spring, modes: would like to be able to disable high/turbo mode to limit to ~ 1.4 amps
That would be great !
I could disable medium press to prevent getting into turbo - but I guess I’ll keep this option.
I’ll probably will use an XM-L, so the current is not the problem and I would like to keep turbo as option.
Main use is planned inhouse at night, so I would prefer to have moon, otherwise I could merely activate the “muggle” mode.
The only downside of the standard Bistro UI is, it only allows the to change the number of levels, but you always get the low and turbo. My problem with turbo is, that this is rather annoying when cycling through at night.
As I posted in OP you can get a custom modegroup as you wish programmed for 1$
just tell me the currents or lumens for each mode
so if you want 2 Moonlights a low and 2 mediums thats possible, there is no need to remove AMCs it can be done with PWM levels,
so if you take the light outside you can go to another modegroup that allows a full bank of 7 AMCs at 100% plus Turbo FET
Wow! Glad you found that! Have you notified T_A of this potential short situation? He may want to update his file to remove those vias that are near the GND plane of the AMC7135. Just moving them over so that they can’t touch the GND should work.
I am currently trying to get confirmation if the new design will fit with the modifications
then a prototype driver has to be ordered
then assembled and send to a member that has a prototype
if it fit then production can start
Price for Q8 driver will be 0.35$ highter than 46mm boards as the PCB is a bit larger
I worked today like 8 hours to get used to diptrace
I will update all boards moving the dangerous vias so that there wont be any shorts,
this dont apply the the boards I did already order last thursday, but I will use some epoxy to block them
