Steel EDC AA XP-G3 from Ali ? (Amutorch S3)
This look pretty.
I think most of us will hope that the pill isn’t glued.
I have the JM20 and love it… not a barn burner but good runtime and plenty of brightness! I might have to try this little guy!
That looks very nice. Hopefully the clip comes as nicely smoothed on the edges as the photo.
Nice find, I bet it’s heavy for its size tho
Yes, will be heavy, but do not expect it to be as heavy as the old C3 stainless.
Nice :slight_smile:
Yeah, I’m proud to have found it by myself :innocent:
I’ll buy it this month I think so I’ll make a little review :slight_smile:
I like the look of it. I think it could be a nice gift light. A gift to myself? :innocent:
Looking forward to it :smiley:
Looks good! Though I think I’ll prefer function over form and get a Zanflare F2, unless a review shows that comparatively speaking, it is a bad idea because this one is AMAZING :smiley:
I don’t know for sure about the F2, but the F2S has a XP-G2 not XP-G3 as this light has. It is also a 2AA light, whereas this one uses single AA. And, this light is steel, compared to the anodized Aluminum F2S. The Zanflare F2S seems to me to be a very well-made light, but it isn’t directly comparable to this one in any way. What is it that you’re going for?
Battery platform. What really matters to me is that it’s AA.
Well, in that case, the Zanflare is probably a better light for you. It takes 2xAA, so it will have better run time than this light. And it’s cheaper than this one by a couple USD. More-for-less! :money_mouth_face:
I just ordered it.
What matters to me is : 1*AA, as slim as possible (17mm), good enough driver without strobe and a tail clicky
Looks like a good host.
Did you order the other light you asked about, that’s even shorter & slimmer.
I was going to say something a couple days ago regarding the use of a 14500 cell, but I forgot. If you want a little more output without burning up the driver, you should try a LiFePO4 14500. Most of these boost drivers are actually rated for either 1S or 2S alkaline. So, the LiFePO4 max charge voltage of ~3.6V is close enough. Most of these boost drivers do happen to survive the 4.2V Li-Ion max charge as well, but that’s way outside the range and could cause problems.
Yep, getting to that conclusion :smiley: Should’ve tried to compare it to the Thrunite T10 as well (more fitting, as it’s the exact same 1xAA platform), but all is good in the hood.
Not yet, I fear that it would be more slippery but OTOH I prefer a reflector rather than a TIR…
But it doesn’t have a clip…although maybe the convoy clip would screw in the lanyard holes… could you check that ?
Eheh, same reasons I ordered it :wink: Using it with a 14500 can be a plus, but 1AA (Ni-MH) will be enough :wink:
The quality seems really good! :+1:
Hum, aren’t those a bit harder to find? Never had one of those… And normally I don’t seem them when searching for the 14500! Or maybe I just overlook them :expressionless:
The “funny” thing about this model (i don’t know if it is exactly this light) is that on the Amazon store where I found them, it is mentioned that they can be used with 14500 batteries. Being the Li-Ion the most common, I believe they refer to that type of battery…
I’ll just have to try them when I get them :smiley:
Thanks for your information about the LiFePO4 14500 :+1:
They are easy enough to find on eBay (at least for me). But, I failed to mention that they don’t hold as much energy, so run-time will suffer, even compared to Alkaline AA. :person_facepalming:
