For the seriously anal retentive (I am not at liberty to disclose my source) you may want to take out the rear end board (oops, sort of back part) and use a little very fine emery paper on the drilled/threaded holes. There are little bitty pieces of metal sticking up from the threading process. A very short burnishing removes them. Theoretically that could maybe possibly improve current flow.
I have the same marks on the bezel as mentioned above. It rather looks like maybe a programmer started the retraction of the machining blade a bit too soon. It looks sort of like a wave function from something oscillating (stepping up). I don't really care.
My approach to simple tuning is probably going to be something like this. Clean any trash (there is very little) out of the grooves with my wife's toothbrush (that is confidential information). Remove the rear PCB, hone the tops of the threaded holes a bit, and apply Stabilant to all the conducting surfaces. I am thinking I might just add a bit of solder to the base of the springs before I apply the Stabilent. On top, the surfaces are in excellent condition and clean. Same approach as the rear. Catch the toothbrush when she is not using it and clean the threads. Knock off any irregularities on the top edge of the tube with the aforementioned very fine paper. Lubricant as yet not selected. Tungsten Disulfide in the Buckyball form is my lubricant of choice; but it is so messy. Clean and treat the contact surfaces on the tube and PCB with Stabilant. From what I can tell that should double the output.
The UI has the ramping, battery check, mode memory and lockout and is identified as āEmisar UI V2. Per Joechina this does not have the ability to program modes like NarsilM. I can only go by what Vinh says on the Sky Lumens website as I donāt physically have it yet. It looks like Vinh keeps the interface without changing. It still has the ramping that I love so much in my Q8ās. Thanks to those who have corrected my misconception.
One of my 2 Q8s came yesterday. The other probably passed my house and went on an east coast tour, smartpostā¦
Anyway, the thing is a tank! Itās smaller/thinner than I thought it would be, but more solid. The beam reminds me of my L6, but in a more compact package and with a cooler UI. Super satisfied, thank you all that were involved with making this happen!
Got my Q8 today. Light works OK. But the packaging took a beating outer plastic bag was torn and had small puncture holes in it.Inner box had one flap torn off and has crush lines on it like someone jumped on the box a few times with the light not inside. Also had to lube the threads because there was almost no factory lube.
Received 2 lights from the second batch, and they are both immaculate. Fit and finish, function, and fun factor - all rated off the chart.
Amazing interface/usability with NarsilM. Sets the standard for all new lights. A brief 5 second demo to friends and co-workers, and they are proās with the basic functions of usage. They are also blown away with this lightās capabilities, as am I.
Thanks to all contributors in the design and execution of this light.
So far Iāve received 5 of the Q8ās I ordered, 4 out of those 5 work flawlessly and are everything Iād hoped theyād be. Itās that 5th one that has my attention, it appears as though this one will not fully turn off the main LEDās, instead they constantly remain on in a very dim state. Iāve uploaded a video displaying the issue Iām seeing. Hopefully the Q8 Team can work with me to get this issue figured out and resolved.
Would it be possible for someone with a more in-depth knowledge of the driver circuit (I know nothing about how it works), please tell me what to inspect and/or test, to determine why the LEDās are constantly getting that trickle of current which is keeping them dimly glowing all the time? Iām not too shabby with the electronics, so if necessary I can open it up take some more detailed videos/pictures of the driver circuit, solder/desolder wires, do some testing with my Fluke digital multi-meter, bench power supply and/or test load. Anyway, I will probably need some guidance to really determine what is the problem with the driver, so please watch this video and let me know what I should do nextā¦.
Seriously:
I first would look for a short at one of the SMD components. Some excessive solder, might be. Perhaps you can upload a close up picture of the driver.
If you deactivate the switch LED - do the main LEDs still glow?
Good to hear, appreciate it! At times I feel all beaten, battered up over the little things goin on. I've gotten similar feedback from 5 co-workers that have them, and still a few more Q8's on the way to others. For many, once they see it and use it, it becomes an "I got to have one" thing.
Yeah Tom, you did more then good.
As a matter of fact the behind the scenes support you gave, sending new parts to some, swapping a problem riddled by a fully tweaked blue switch LEDs one, amazing.
Some people just donāt get how much energy it takes and has taken you, so just ignore some who keep on asking a bit
ElginAgain that does not sound good, what is your level of soldering?
As for solutions, new parts for those with problems are accepted BT Thorfire. Expect action on this soon.
I had my two at a robotics team meeting last night. Several people played with them and were very impressed - even more so after I gave one piece of advice: ātry click and holdā. I had a couple students hold the lights and light up a few sheets of plywood for me so I could cut them into smaller pieces with a circular saw. We actually had to turn them down from max because there was simply too much light. Plenty of light saber noises were made and beams pointed into the night sky.
The adults were very interested when I told them that there is an AtTiny inside - I can never remember which model it is, just checked the first post - it is an 85.
Itās strange, but Iāve received mixed reactions on my Q8 lights.
Some instantly see how cool and powerful it is.
Others see how cool it is but when they ask about the price, they scrunch up their noses at the thought of spending so much on a flashlight.
People obviously place different values on the things they buy. One friend has spent many times over the value of his Subaru with all the aftermarket add-ons that pretty much only add bling. Another loves seeking out limited runs of craft beer and has a cellar worth thousands of dollars. Another friend spends a chunk of cash every so often on super-steel knives, but is happy with his 2xAA Mini Maglight.
My son and I really, REALLY love the awesome power at our fingertips when we played around with the Q8 last night. Heās not ready for lithium-ion cells and has to enjoy his Eneloops for now, but I can see him seeking out the big boys in the future.
