Digging a little more, the last remembered level is not save permanently, so if you cycle power by doing a mechanical lockout for example, you lose your last saved level.
Also if you are referring to MODES operation (not ramping), the factory default is no mode memory.
Assorted choices for assorted likes of assorted people. I do absolutely love the UI as it comes. For me the Q8 has the best out of the box UI of any light I have tried or read about.
I’m having a lot of fun shinning the Q8 around. Can’t help on the double click!
However, since the switch leds are much brighter then expected - you can move around the house at night just with the green glow, did anybody estimate or measure the parasitic drain involved?
Assuming the production version has the same drain as the prototypes your talking years, so no worry.
As always, if your not using the light and it’s going to sit a long time, just twist the battery tube to break the connection.
Maybe someone can measure the drain on a production light that has the overly bright switch leds?
Just take a DMM and set it to measure DC current and use one battery then use just the head facing down. Touch the positive tip of the cell to the big ring then run the DMM wires from the cell negative to the outer ground ring on the driver. Should be pretty easy. You may have to wait 6 (?) seconds for the mcu to go to sleep.
My local usps has it. I can tell because the sky is lit up down across town hahaha.
I’ll have an update tomorrow . I can’t wait to try this thing out. Ever since it was first discussed. I am the one that asked for low voltage protection and you guys put it into the list right away.
It is cool to have been a little small drop in the bucket of this light from back when you guys started discussing it. ( post #20)
Man, I don’t come here often and this is my fist new light in a while, but I’m EXTREMELY impressed. The UI alone is a massive feat, with so many features that I haven’t even attempted to try them all. I just regret not buying as many as I could possibly order at $40, that’s just an absolute steal.
I want to thank everyone involved for doing such an amazing job on this!
Can’t wait for mine to show up! BG has the tracking number but I don’t know where to track them…. I even throw the whole number in google and tried each carrier. And none of them were correct… Same thing goes with my MF01.
Expected delivery date are 10/23 for the MF01, and 10/26 for the Q8 But I have no idea where they are staying now lol
I tested my production light and registered 20 µA with the LED off. Given it’s not a high end DMM and the variance is only 2 µA, I’d say production is the same as the test sample.
