PM sent
DELETED! Sorry, this doesn’t show the products accurately
Sorry Boaz for this mess!! :person_facepalming:
Nicely done informative post MascaratumB :+1:
I just ordered some to try out on a few lights that could use a bit of something.
I’m optimistic that it may help me to get more use out of them.
MascaratumB, very nicely done. Thanks for your effort putting this together! From my own experiements, I like DC-Fix the most. I just don’t know of a good way to remove it after I apply it to the outside of the lens because most flashlight bezels cannot be removed.
You should add this post to your sig!
Thorfire TK4A
Before
After
Before on medium
after medium
( better target.)
MascaratumB I really appreciate all your efforts here .
I have no idea why your camera was overcompensating ? or why your beamshots weren't showing what visually you were seeing . l picked the Thorfire TK4Aone of my uglier green tinted XPL-2 with a smooth reflector with a bunch of throw to show on a white wall how dramatic the change is from before and after adding a single sheet of diffuser film
Hey, sorry Boaz! I really had a big trouble with the cellphone as I mentioned so that’s the thing, my photos were not showing what the diffusers really make in “naked eye” perception!
I wanna say sorry to all the members that saw it and thought that it was a “nice” thing, but it was not! After Boaz pictures I realized that, we’ve been talking through PM and then came my decision to delete the threads!
I hope I can to better beamshots to really show what these diffusers can make
Again, sorry for this situation and I hope you (all) understand! I wouldn’t fail if I wasn’t human
Best regards :+1:
Received DC-Fix from Boaz today. It was applied to two Maglites; ML300LX and ML50LX. Fortunately, it's easy to unscrew the top of Maglites, so the DC-Fix was applied to the inside of the lens.
Beamshots are from the ML300LX:
As you can see, this vastly softens the Maglite beam. Note that I turned this photo into black & white, as it was almost impossible to get the color tint the same as it looked to the naked eye, and wasn't important anyway.
And the final product. Our recent snow here in Oregon was good for something.
Been a little busy, but my prize from the giveaway arrived a couple weeks ago. I am looking forward to trying it out.
Thanks Boaz!
I was pretty excited to see that this diffuser film KILLED the green on these thorfire lights. pretty impressive .
sadly when I tried it on some funky green NW ut01 lights it didn't work ..So on some tints it will knock out green ..In every light it will blend all color in the beam .
Pm sent for an order. Or is you paypal posted somewhere I am not looking?
EDIT- Paypal sent
Was thinking of getting some just for s&g, but was curious… does it just blend the beam, or actually make it floodier?
It does both .
On really ugly beams like xpg-3 with a poorly adapted reflector you can have a crazy amount of yellow in the hotspot and a silly amount of purple in the corona .and it just blends it all together and makes a much much better tint.
I’m guessing that the greatest impact is just because of the proper mixing of all the colors .
- One of my worst lights had a Big Black Hole right in the center of the hot spot , as well as crazy rings in the beam and the same yellow hot spot and a purple halo . Pretty cool to see a really nasty beam turn out buttery smooth and the color go from bad to very acceptable
One thing I like about diffuser film is it softens up the edges of the beam.Where an aspherical lens zoomed out into full flood has a distinct edge that separates light from darkness.
I used to think I liked that dramatic cut off of light and now I think it just draws my eye to it. The softer edge allows me to look where I want and doesn’t force my eye .Sounds silly but I think it’s true .
Got mine in mail today. Took about 15 minutes to put on. I put on wrong stuff first. Wasn’t paying attention.
Easy if you can get the lens off. Got photos I can email if anyone wants to post them.
Edit, I have imgur. loosing my mind
Before
After
I cut larger piece then needed, peeled, laid sticky side up. Placed lens on side. Trimmed around outer edge.
The paper is to prevent finger prints.
Finished cutting
Lens back in, I put fix on inside, don’t think it matter with this light as there is 2 O-rings.
Taking it out for a dog walk after a trip to walmart to look for some grip tape.
