Nothing changed, everything is as shot except exposure adjustments (those were two different flashlights with slightly different brightnesses). 219C has greener tint while E21A is right on the target (check Maukka’s chart below)
WB adjusted to get rid of tint differences. This 219C has R9 = 76, one of the best 219C in my collection. But E21A still wins.
Sad but understandable.
Personally I think the same….but just initially.
That’s because there are no stars for it and it is not well known.
But for most applications that I can think of this LED should be technically better than XHP70.2 (I don’t know the price, so it may not be so good commercially). I hope it catches up….
It could fit the Virence VR16S1 Star with scratching.
And as driver it would work with 4S Buck-Driver like it is in the GT.
Haikelite MT07S could be a good host for it.
Being higher voltage than the XHP70.2 used, the MT07S would probably drive the 149 pretty hard. Given the mode spacing of that light, I suspect it would work well.
I’d buy one, but probably only one. That doesn’t make it worth stocking.
And so it did a few days ago, thanks Clemence for checking the whereabouts of the package for me!
Here is the first of the E21A sm205 R9050 leds in a Lumintop Tool. The tint and colour reproduction is not far from the 2000K Stanley led that I tested before, of course the Nichia has just that bit more red in it
I found a single 3000k to be fantastic in a zoomie. In an ultrafirr uf10 to be more specific. It is about 2amp direct drive off a fresh imr 16350, just about its max spec
Due to Nyepi Day (Silent Day) in Bali island some of the recent orders can’t be shipped until 180319. All public electricity including traffic, airport, internet, etc… will be shutdown in 1803(17-18). The following orders are already collected at the local post office this morning.
- 10193
- 10192
- 10191
- 10190
- 10189
- 10188
- 10187
10184
For your information:
The nearest reliable post office located 23km from the workshop, thus I normally only ship twice a week (monday & thursday).
Correct, this is the only true “earth day” in the world I know.
You can see the milky way clearly at night. No sounds but from the animals and babies. Very clean and fresh air like those found in virgin forest. Bali usually saved hundreds tonnes of fossil fuel during this day.
Can you talk more about this LED? How similar is it to candle light?
I once had a light with a de-domed XP-G 3000K 90CRI and it was just terribly orange.
I have an old Novatac Wichita which has a special driver (like in the HDS lights) with very low modes. It seems like a good match for this LED. The lowest mode actually flickers a bit, so I would even have the candle part covered :D.
It obviously makes sense to put this LED into smaller, dimmer or very floody lights because of the low color temperature, as shown by the Kruithoff Curve.
