1. Zebralight SC600w Mark IV 18650 XHP35 Neutral White High Intensity
2. Zebralight H604c XHP50.2 Flood 4000K High CRI Headlamp
I actually have them just for this reason - if I should take only 2 lights for longer time. They do almost everything well in a compact package with good reliability and efficiency, batteries are interchangeable also. Not the cheapest solution, but if only 2 lights are with me, I would hope for higher reliability for longer time.
2. This one is a bit more tricky… if it was a thrower, I’d say the Emisar D1S. If I was to cheat a bit, I’d say a P60 host+modules including a Nichia 219C, XPL HI, UV, etc. Overall, I’d probably go with the BLF A6 in 5A tint, or ideally modified with a warm XPL HI.
I always thought these flashlight people were nuts. Ordered myself an H03 on here and planned to stop there.
Then, was offered reviews, and found giveaways.
So far I have:
- Skilhunt H03 (paid $23) - keeping
- Sofirn SF14 (free from review)
- Thorfire TK05 (free from review)
- Thorfire TK01 (free from review)
- Sofirn C8A (free from review)
- Folomav A4 charger (free from review)
- Nitecore LA10 (won in giveaway)
Thorfire VG15S (won in giveaway).
Oops. Looking to sell most of the above if anyone is interested in brand new flashlights. Only plan to keep the H03 and Folomav charger I think. Maybe the sofirn C8A. I just have too many and am moving soon. Also have a liitokala and a bunch of batteries as well, of course.
Once upon a time was the SP10A. I imagine there might’ve been a regular SP10, but ain’t sure. Anyhoo, the A had l/m/h and 2click for strobe. Then came the SP10B, and the B had f/l/m, 2click for h, 3click for strobe, 4click for lockout. The red and blue Bs followed suit. Then, the red/blue remained Bs, but the black Bs were relabeled and sold as the new As. Then, I think there were tweaks to the new-new As, but I don’t have any of those. Then the new-new SP10s and v2 that was just released not too long ago.
So you need to specify old/original A if you’re talking about l/m/h+s, vs the new A if you’re talking about f/l/m+h+s+LO.
Confused yet? Again, that’s not touching the new-new As with tweaked UI, or the new v2 of the SP10 family.
Oh, it’s not that I don’t like either the A or B. The B has a nicer tint, whereas the old A was a bit greenish. Just that for a nightlight, you can stick the B on firefly and turn that on normally, but 2click to get instantly to high, even from off. The A has the regular rotation, and being that in the Bs firefly is really firefly (sublumen) and only really useful up-close, the A can come in handier if you don’t need/want firefly.
So they’re just different, and which UI you want for a given purpose is what’s the better light for that purpose.
Most times, I keep reaching for the old A, despite the green.
Agree.
There are always 2 lights in the car, a compact thrower on LiION, and a glove compartment light on NiMH.
When I get into the car, that’s 2 more lights. One in my BOB. My Enogear 14500 SS in my breast pocket.
Ever since I bought that last light, it goes wherever I go. Except under the shower.
And when I am on a holiday, there is a backpack loaded with whatever I think is useful on that trip.
Sounds pathetic, I know.
Frankly my dear, I don’t give a d*.
You don’t have to schepp it around.
I really like mine. Build quality is great. Nice machining, design. Nice clicky and a great beam and tint.
Played with mine a bit, but I also ordered an other one to keep stock. Keep in mind that shipping will take a long time with this light.
The size is about the width of my fist (small hands). With an SS body, you are carrying around something with enough weight to be a bit re-assured that you are not completely empty-handed.
It has three modes, low-mid-high, no memory. And a crisp tailswitch.
I consider the build quality quite good. Nothing is rattling or loose. Finish is smooth, no raw edges. It looks as if some serious thinking was done before it went into production.The design has some drawbacks, however.
The head is connected to the pill, as is the body/tailcap on the other side. The 12mm ledboard is pressed down by the TIR + loose led centering ring. The 14mm driver has a very slim retainer ring. The switch also has a retainer ring, from the outside. Both with curved indentation, no holes or notches.
My problem was that you can’t predict to what part the driver will stick when opening the light: head or body.
I glued the led centering ring to the led board and the head assembly to the driver (I made some notches in).
Not crazy-glue, however. And I replaced the one-heartbeat-from-DOA XP-G by an XP-G3 (Fasttech € 1.49).
1. Spark SG5 CRI (warm white). Why? I have a two digits number of headlamps and 95% of the time - that’s many times per day - I am using this Spark.
2. Klarus XT2CR. Why? Because I always carry a 18650 tube light in my pocket and among my tube-lights, I like this more.
Only two lights is hard… I need to opt-out many lights that I like and use just because my main light needs to fit in a pocket. So, I am not selling them you weirdo
