I purchased a Novatac SpaDefense SPL-120 Tactical and spent several hours learning how to reprogram it to a Civilian configuration, equivalent to a Novatac 120P model.
here are the baselines, and what settings change
stock 120 T configuration:
click = 120 (maximum) lumens
double click = 10 lumens
tripple click = .33
from ON, press = Strobe
from OFF, press = maximum lumens (press uses the Primary mode and momentary)
from OFF, click press = Momentary Strobe
from ON, click press release = Strobe
Momentary, mode 7, ON
Ramping, Mode9, OFF
stock 120 P modes
click = 11 lumens (set by using double click hold, to ramp up, cycles through strobe and SOS and minimum)
double click = 30 lumens (set by using double click hold, to ramp up, cycles through strobe and SOS and minimum)
tripple click = .33 (set by using double click hold, to ramp up, cycles through strobe and SOS and minimum)
from ON, press = 120 maximum (this is set from click press from on, then double clic hold rising ramp until maximum, indicated by double flash. release at desired level, click turn offā¦ press level is saved)
from OFF, press = 11 lumens (this is set by Primary mode)
click press = maximum (set by using double click hold, to ramp up, cycles through strobe and SOS and minimum)
Momentary, mode 7, OFF (from On, triple click hold to get to the 9 step option menu, release, click 6 times, hold till light turns off to toggle setting)
Ramping, Mode9, ON (from On, triple click hold to get to the 9 step option menu, release, click 8 times, hold till light turns off to toggle setting)
If the light is not factory unlocked, the back door is to do 250 clicks from ON, and then HOLD for 1 second and releaseā¦ the light will be flashing
then click slowly, 8 timesā¦ the light will be on, now hold the button down until the light turns OFFā¦ and release the button. The light will turn on again. Now turn it off, and youre done.
the light is now Programmable.
If anyone has a Novatac that is not already programmable, and wants help cracking it, Im willing to help
UV light excites a 219b 4500k 9080:
Ive been reading about the HDS Rotary for a while now. I have never touched an HDS before this Novatac.
Instead of diving in to an HDS Titanium Rotary, I decided to start with this less expensive older version. I wanted to experiment with the mode ramping feature.
I think I would prefer a Rotary, so, if anybody wants this Clicky, PM me for a price quote.
