I purchased a Novatac SpaDefense SPL-120 Tactical and spent several hours learning how to reprogram it to a Civilian configuration, equivalent to a Novatac 120P model.
here are the baselines, and what settings change
stock 120 T configuration:
click = 120 (maximum) lumens
double click = 10 lumens
triple click = .33
from ON, press = Strobe
from OFF, press = maximum lumens (press uses the Primary mode and momentary)
from OFF, click press = Momentary Strobe
from ON, click press release = Strobe
Momentary, mode 7, ON
Ramping, Mode9, OFF
stock 120 P modes
click = 11 lumens (set by using double click hold, to ramp up, cycles through strobe and SOS and minimum)
double click = 30 lumens (set by using double click hold, to ramp up, cycles through strobe and SOS and minimum)
triple click = .33 (set by using double click hold, to ramp up, cycles through strobe and SOS and minimum)
from ON, press = 120 maximum (this is set from click press from on, then double clic hold rising ramp until maximum, indicated by double flash. release at desired level, click turn off.. press level is saved)
from OFF, click = 11 lumens (this is set by Primary mode)
click press = maximum (set by using double click hold, to ramp up, cycles through strobe and SOS and minimum)
Momentary, mode 7, OFF (from On, triple click hold to get to the 9 step option menu, release, click 6 times, hold till light turns off to toggle setting)
Ramping, Mode9, ON (from On, triple click hold to get to the 9 step option menu, release, click 8 times, hold till light turns off to toggle setting)
If the light is not factory unlocked, the back door is to do 250 clicks from ON, and then HOLD for 1 second and release.. the light will be flashing
then click slowly, 8 times… the light will be on, now hold the button down until the light turns OFF.. and release the button. The light will turn on again. Now turn it off, and youre done.
the light is now Programmable.
If anyone has a Novatac that is not already programmable, and wants help cracking it, Im willing to help
UV light excites a 219b 4500k 9080:
Ive been reading about the HDS Rotary for a while now. I have never touched an HDS before this Novatac.
Instead of diving in to an HDS Titanium Rotary, I decided to start with this less expensive older version. I wanted to experiment with the mode ramping feature.
I think I would prefer a Rotary, so, if anybody wants this Clicky, PM me for a price quote.
