Not totally relevant, but in addition to the M1 &M2, Convoy briefly offered an L1 that used either 1 or 2 18650s (with the included extension) and ran an LD29 driver. The head is a bit bigger than the M1, and the reflector is deeper. The tube handles two protected 18650b’s with ease, with a plunger tailcap and a tail switch that takes serious thumb power to activate.
I don’t know why they dropped it, except that it might have been too expensive to build or fit in with their product line. I have one, and it’s a tank! It’s another whole level of build quality over the M2, and I see the M2 as outstanding.
If you ever come across an L1 in good shape, don’t pass it up. I know for sure I’ll be upgrading drivers and emitters in this one for years to come.
Many users have the new Convoy M1 and M2 torches. I also have it
On the weekend I will try to compare the old and new version as I did with Convoy s2+ . I hope you will want to see the video
Well, the SST-20 is about 30% throwier on average per lumen compared to the XP-L HI.
So, with something like an Convoy C8(65kcd), since efficiency of the XP-L HI is about the same as the SST-20 5000k, the SST-20 would be easily making 85kcd without any change whatsoever.
Buy osram white flat and gaskets from Hank (intl-outdoor), M2 host and 3000mA driver from Simon and stack some more 7135 chips. This will outthrow every other M2 mod :D.
