Where to get eneloop + charger?
mfm I have this charger. sanyo NC-MQR06W.
What is the best charging rate for the follow?
1xAA is it 560mA or 1680mA
2xAA is it 560mA or 1120mA
1xAAA is it 280mA or 840mA
2xAAA is it 280mA or 560mA
The question I'm trying to ask is that I want batter life, if I charge at the higher rate will it effect the battery life or capacity. Speed is not that important to me but the faster the better without effecting the battery life and capacity.
Thank you.
hopefully mfm understands your question. we're talking about Eneloop AA's, right? here is kreisler's contribution summarized in a nutshell after having studied the subject on CPF plus my own experience confirming it:
+ Eneloops are cheap. Check ebay, 1 cell costs 1.70€. other brands purchased from a local small retailer are more expensive! so dont be worried about price/loss of money or eventual aging effects after 10yrs of use!
+ Eneloops are no-brainers. they dont age (if you have C9000 to do a forming charge called "Break-In"), and you dont have to take special care of them. whatever and how often you do with them, no problem. other cells would age because of a user's abuse, Eneloops dont. if there is an Eneloop flying around in your house and you dont know its charge status (100%, 60%, 20%, whatever) -- and this is the case with most users in the world because only few possess a DMM or C9000 or BC-700 -- then just use it (until depletion) or recharge it. this decision will not affect the Eneloop's life or age or quality. Eneloops are robust, keep their charge, and they are designed to be used this way: as no-brainers. Just trust Sanyo/Panasonic and the 1.70€ which you once paid for it!! -- And once you learned to trust this no-brainer procedure, using Eneloops will turn into joy and green and happiness, instead of worrying about aging, cellulite and whatnot.
+ have you read the info in this thread, incl. the PDF-specs sheet for Eneloops and discharge graphs? you'll learn that the Eneloops like "high flow rates" .. at least they dont harm them. call a C9000 technician and ask him/her about charge and discharge rates and he/she will answer "Eneloop or not, choose 0.5C charge rate and 0.25C discharge rate; since Eneloop 2000mAh are the most common rechargeables nowadays the C9000 is already pre-programmed that way. i.e. 1.0A charge rate (yes, this high!) and -0.5A discharge rate", see also the official C9000 FAQ's on the Maha website.
+ the 1000mA/-500mA is a common accepted and agreed upon "standard" on cpf. if you believe in the power and wisdom of cpf, then you need to believe this outcome/result/finding: 1000mA/-500mA --- simply adopt it, and forget about your doubt, worries or questions
+ there is no proof or long-term study which proves that deviation from this 0.5C/-0.25C rule for Eneloops results in better quality Eneloops (i.e. less aged cells). in fact, Eneloops are only a few years old, and even early adopters of Eneloops report that after years of use and abuse their Eneloops (which they had never taken special care of) are still like new. pretty much unaged. this holds true especially after mfm's mentioned forming charge with a proper machine (e.g. the C9000).
In summary, Eneloops are simply awesome. Charge or recharge them anytime, dont care about topping off or the current charge status, and they will last you for several years to come. No special care needed. You can even discharge them to full depletion (that's what i do in my hundreds of runtime tests. you know my BLF reviews!), no problem whatsoever. With other NiMH cells that would be a problem, with Eneloops it isnt anymore. Eneloops are really really special in every respect. And cost only 1.70€ per cell!
Okay, cpf also recommends that you get a C9000 and play with the cells (e.g. doing the Break-In every 6 months or so, and analyzing the cell's effective capacity once per month or so -- to be certain that they really havent aged haha) but Eneloops can live with Sanyo/panasonic chargers equally well .. because they are no-brainers.
Hope this helps. You got a nice charger!! :)
The more I read oon Eneloops, the more convinced I am that they only have one problem.
They are so durable, that no one yet knows for sure how long they will actually last in common use / keeping on shelf :smiley:
CheapThrills, you dont have Eneloops yet?
1.70€ apiece!!
:p
I have enough of them, just a no-brainer and they are now even cheaply available on-line in Finland!
I got my ones for £1.12 each
So me charging them at 1680mA, would have no problems? That's the max charge rate for one battery.
I’ve been charging mine at 1.5A all the time and I never had any problems - I guess extra 180mA won’t make them suffer either :slight_smile:
Only thing that seriously hurts eneloops are those pesky 15 min chargers.
Thanks Shadowww
Eneloop AA are specified for Fast-Charge at 2000mA (see its specs PDF), in 1.1hrs, which means that Sanyo/Panasonic lets you charge them with up to 2.0A.
cpf and Maha corp (and kreisler) recommend 1000mA; the cell will stay cool for the entire session.
check with 1680mA. if the cell gets warm, then it's not bad .. but heat itself does degrade a cell's quality (aging, capacity, LSD). Normal NiMH's would degrade by 2.0A and its produced heat (no doubt!), Eneloops not (robust!).
Just check the temperature and report back, thanks!! ( oh man, sometimes i can be real smarta$$ haha )
Question:
Which is the best (or most recommendable) of the Sanyo NiMH chargers (and why)?
Friends ask me about good chargers but dont want to pay the BC-700 or C9000 price, tss.
From what I've read, none of them is really good because they dont follow the NiMH charging algorithm like BC700 and similar do.. therefore I'd buy the MQR06 because its the fastest. ;)
Oh, and for that price, you can get a BC700. Oopsie. :P
you are right thanks NightCrawl!!
the very best charger from the Sanyo NiMH charger series is the MQR06. It has 4(four) LED's!!!
costs 17.99$ shipped, please buy and use coupon code kreis*rap on your preferred shoping site :D
http://www.ebay.com/itm/190655219243
I thought the "the more LEDs, the better" was only valid for flashlights, but if you want to use that rule for a charger, I'm fine with that.. :P
BC700 is 23€ shipped from Germany.. ;)
i am wondering if the MQR06 (~18$) is a better purchase than the i4 V2 (19.xx$). the BC700 is out of line! :P
None of them chargers NiMH correctly, so if he might switch to LiIon, give him the i4.
But keep in mind that these Sanyo chargers are only good for Eneloops.
okay, will keep that in mind thx :)
i will suggest both chargers because they are priced similarly. If one uses exclusively Eneloops, then the MQR06 would be better imho. Because it charges faster!!
Would GP PowerBank Audio be OK for Eneloops
Actually the MQR06 follows correct charging algorithm for NiMH, with delta-V termination.
It also charges cells individually, and not in pairs. And here in Europe, MQR06 + four Eneloop XX bundle costs much less than the BC-700. :stuck_out_tongue:
Chargers and eneloops here:
http://www.batteribyen.dk/genopladelige-batterier/genopladelige-batterier-sanyo-eneloop
6 dkr = 1$
Then it maybe was one of the smaller.. but here in Germany, the price for MQR06 + four Eneloops is the same as the price of a BC700. But the BC700 is much more useful. :P
