Convoy L2 XHP50.2 K2-1C outdoor performance
LD-B4HV 2-12Amp 2S/4S Multi-Cell 17mm Constant Current LED Flashlight Driver (External MOSFET Support)
20mm MTN-BST3 Boost Driver
He said he doesn’t plan on making any more of these.
He has new options I suppose. I haven’t looked at his drivers for 12V use lately, bet he could shed light on it though if asked. :wink:
Is there an L2 extension tube available separately? I’ve seen pictures of an L2 that comes with one that looks like it’d screw into the L2/L6:
Asking because I just got an L6 and it’s great, but surprisingly it’s smaller than I’d hoped for. Would love to be able to add an extension tube or two and swap the driver for a 3S or 4S one to have a proper maglite form-factor replacement with modern internals!
sorry ,i dont have extension tube
How about using sst40 shave dome on the l2 ? 200kcd easy.
Hello Simon,
Any news about L2 on XHP35HI ? :slight_smile:
Hello Simon!! apart from keeping our pockets empty LOL, is there an interest from your behalf of making a helmet light for mtb or mounted on the front of a bike, thanks!!
I am waiting for the driver with 2 cell for Convoy L2. It works with xhp 50.2 or something similar for about 2400 lumens.
L21A with XHP35 HI will be available soon ,the output current of driver is 2.3A
This would be awsome, but 1000mah is a bit low. You would get better lumems and lux number with a sst40. 2000mah minimum for the 12v xhp35
Thanks Simon, looking forward… :slight_smile:
Hi Simon,
Any estimated date for releasing L2 XHP35 ?
Whats wrong with the reflector? Is the opening to wide and it sits to high? People have done it on here already.
although the diameter of L2 reflector is small than L6, but it’s more suitable than L6 ,i campared them several times ,
L2 reflector can get more LUX
Driver is in production ,i’m not sure the date
Hi Simon,
I saw l21a on xhp35hi already available ! This is running on single 18650/26650 cell, how about luminosity and distance of the flashlight ? I’m right now ordering it :slight_smile:
I thought the L21A runs on 2x21700, while the L2 runs on 26650, or 18650. The M21A runs on 1x21700, and is the 21700 version of the C8+.
Is there a new L21A running 26650?
The L21a runs on 1 single 21700 (i bought one recently)
It does NOT come with an extension tube. (It doesn’t come with any accessories actually, not even a lanyard…)
L21A runs only 1*21700 or 1*18650 w/adapter.
26650 only on L2.
