I don’t think a protected cell is mandatory.
Just don’t overuse the light or leave it tailstanding.
I mean for safety measures. Keeps out of reach of children too
definitely!
For Children, a High CRI HDS is safer than an RRT-01, because
HDS are not 18350 compatible,
are limited to 200 lumens,
have a 33% auto step down at 40 seconds,
and auto shut off at 3.0v
Preposterous Proposition Warning:
A resident of the State of California has determined that the RRT-01 is not suitable for children.
Responsible use of 18350 LiIon flamethrowers requires an “intelligent” adult operator.
I don’t think I’d want to hand a child a nearly $300 HDS flashlight either.
Safe for the child maybe. Safe for my wallet no!!!
Child can make do with a $3 light from the local store.
No high powered flashlight is safe for a child. All they need to do is point it at their eyes and try to brave the light… leading to retinal damage.
outstanding review, thanks for the great photos too
and now Ti ala CRX
Laissez les bons temps rouler!
Differences in the Original RRT-01 and the New Version with Brass pill.
2. No strobe on Original RRT-01. Yes Strobe on New Version.
3. New Version pocket clip is long, past the control ring. Some Originals got short clips, and they can still be bought.
4. New Version is set for higher max power draw.
5. New Version fits 19mm Carclo without modification to the diameter of the optic. Original requires customizing the optic’s diameter.
New Version RRT-01:
Original Version RRT-01:
6. New Version is XP-L, Original is XM-L. They have different reflectors, the Original has rings in the spill beam.
Original RRT-01 / TCR-01 did not require any modification to the Carclo optic to make it a triple. The optic fits perfectly. However, the edges of the star do require a little filing down.
Are you sure about that?
I stand corrected.
Based on that photo I opened up my TCR-01 triple to double-check the optic. Looks like I did modify the optic after all so that it would fit.
However the modification to the optic was extremely simple. All I did was file down about 1/4 to 1/3 of the outside of each of the 3 legs. Basically 5 minutes with a small handfile. None of the rest of the optic needed modification… just the legs.
Yeh, that sounds about right
I wasn’t sure if maybe the rrt-01 or the optic might’ve changed slightly.
Just found this one:
https://skylumen.com/collections/one-off/products/one-off-rrt01vn-triple-quad-rustic-editions
Why did he scratched them like this ? It’s ugly no ?
Mine now rocks a 219B and an OP reflector from an Eagle Eye X2R.
I had to grind the outer diameter of the reflector by about 1mm.
I removed the stock centering gasket to allow a better focus, but the beam is not that good…
I might try with a 219C, the old 219B is too cold (I think it’s 5700K)
Triple 219B 4500°K…
…150$
Where???
@id30209, check your link >> options >> TRIPLE 219B 4500K
OMG! There was only W2 option when i saw it this morning!!!
Thx for opening my eyes bro!
@X3, since you live in france, I can throw a 219B 4500°K and a 219C SM4070e in an enveloppe if you give me your address in MP. Can’t do more, I don’t have much left.
X3 check your inbox
