I have that board thermally improved a lot filling vises with solder, placing a lot of them from ground plane right next to the FET planes
I guess up to 5-6A should be no problem with that PCB, 2 layer MCPCB would be too expensive
there is no single 20mm MOSLED DTP MCPCB for 3030 LEd that I am aware of
also the driver runs on 2.8V
I need for OTSM with also a diode after the LDO
the MOSFET has to have a low resistance below 2.5V for good reguilation at lower battery level
SIR800, 404 and the Infineon BSC009 have down to about 2V relative constant low on resistance
for LFPAK33 package I need a new MOSFET with similar prroperties
CC FET OPAmp has to compare the voltage over the shunt
relative to to the PWM cycle which gets transformed to a DC voltage
The OPV changes the FET resistance to match both voltages the same
But for a constant max current the PWM voltage needs to be aleways the same amplitude so I have to use a 2.8V LDO
I didn’t mean to suggest switching entirely to FET on MCPCB but rather offering it as an option. LD4B can regulate 12A. And maybe FET removal would enable shrinking the driver so it fits more lights.
legally I can also set them back to original non A version, but why is it they sell me the hardware with locked features
unlocking cost 70-80% of the PSU?
So is it legal you reflash the firmware on a driver?
its just a few bits in a a code line that make A version or non A version, no hardware or special calibration
the calibrated PSU costs another 300€ more
I don’t know anything about it, but if it comes with any kind of user agreement, then that could be the basis for the “legally” that Jason mentions. Other than that, it’s just a loss of warranty, since they “legally” don’t have to honor a warranty on a modified piece of hardware. I say go ahead and do it, as long as you are willing to take the risk.
EDIT: I just want to add that people have been fighting this kind of “anti-feature” design for a long time with technology, including Microsoft Windows, Canon digital cameras, Apple iPhones, even Android phones (supposedly open source software). Those are just some of the examples off the top of my head, but it seems to me that the more expensive the technology is, the more likely that the manufacturer will install “anti-features” so you have to pay even more money to get full functionality.
Legally it’s complex and depends on jurisdiction. Manufacturers often want buyers to be licensors rather than owners. Some countries push back more some push back less.
the thing is both firmwares are identical, the hack changes only in a file DP811 to DP811A,
so its one byte of data changed which makes the difference from a limited to unlimited features supply
It is my property if I want I can throw it out of my window and beat it to a pile of scrap with a 4 pound hammer,
guess trying to claim warranty successful is kind of hard if I do so
The reason they sell the cheaper model with all the same hardware is because it saves the company money. One item comes off the assembly line and they can make it either version depending on their needs.
The difference in price based on software features allows the company to offer 2 models to fit different people’s needs. If you don’t need all the features, you can buy the software limited version. The company makes a smaller profit on it, but they might make up for it in volume. They probably sell more of the cheaper ones than they do the more expensive ones.
It’s about product differentiation. If they did not offer the cheaper one their competitors will and they will lose money.
What driver is sold as having features turned off that you have to pay more to get turned on? I have never seen such drivers.
Some UI’s are illegal to flash such as Guppydrv. If you tried to sell drivers with it and you did not pay the fees to use it, you could be sued by the creator.
All of this gets into the digital copyrights act.
It is one thing to violate these clauses on your own personal equipment as it is hard to prove anything. It is another story if you buy a bunch of the DP832, convert it to the DP832A and then try to sell them for a profit.
Personally, I would not admit to any kind of illegal activity on a public forum. It could be fine or it might come back to bite you in the rear.
They will still make a good profit on the non A models
Its just ripp off to get a good profit with having minimum costs
for example they limit bandwith like on the function generator
for example the 20MHz DG1022Z costs about 400€ the DG1062Z costs 715€, same story only a byte is set different to enable 3 times more frequency
I dont even bothered to mess with this as I dont need that fast and luckyly also the small one got same poiunt count
for example Siglent dont do this they sell you a full featured scope for 400€,
while the limited Rigol costs also 400€ and it costs you another 250€ to upgrade to get the same features like bandwith and point storage
Another example of this - Alcatel Lucent selling POE switches with 10gbit uplinks and limiting them to 1gbit to sell a license to unlock. Just went through that at work.
Now lets talk about a totally legal hack to make my Fluke 8845A use a PTC to show temperature, offical only supported in the 8846A
but with the maths functions you can do offset and multiplier to show the temperature reading in the kOhms range
Also build me for 5$ a probe instead paying 500$ for a way too big Fluke probe
Both of these are just your opinion. I’m sure Rigols opinion is different than yours. Since Rigol makes the product and sets the prices, their opinion is what matters.
If they see a rise in the lower model sales and a drop in the higher model sales they might figure out people are just hacking the lower models so then they might go to the trouble of leaving certain hardware pieces out of the lower models. Time will tell. Hack while you can. :+1:
