It seems like we all missed your posts for some reason. :person_facepalming:
Make sure your not in muggle mode and then report back what it’s doing. Maybe copy and paste if it’s doing what it did before. I’m still not sure what your describing. Are you trying to change the rate of the strobe?
I’m running into the exact same problem, one head not receiving power. Is yours a 7A tint by any chance?
Curious to know if a multimeter between your (-) wire on the MCPCB and head threads shows any resistance. Mine looks like an open circuit, and makes me think the driver solder joint has failed.
I’m not quite sure how to take apart the FW3A. I am able to take off the lens of the head. If that’s what you mean. It does look like the negative wire isn’t attached anymore.
I have the 3D version. I don’t have access to a multimeter, I’d have to go buy one at the moment. I don’t have any experience with electronics and soldering. I took off the lens and optic, it does look like my negative wire isn’t attached to the board.
I’m not quite sure how I can post pictures on here, but here’s pictures of a comparison of the two heads.
Yes, that would definitely make it not work. I’ve now seen two like that.
I can’t quite tell from the picture if the solder came off the pad, or if the pad came off the PCB. In the former case, it should be easy to fix with a soldering iron. In the latter case, you probably need a new PCB. But in any case, this would probably be a good time to ask Neal for a replacement.
Looks like the old twist & break.
There is no real play in the wires with the FW3A so when screwing the head on you need to make sure the optic/ MCPCB stays put and doesn’t rotate with the part you’re screwing on.
The one on the left looks like mine when it was on turbo for a few seconds & started to smoke then stoped working , then I looked at it I noticed the wire was off.
It would be good if it were just that , I haven’t bothered soldering it back on because only two leds are working properly ,so I’m waiting on Neal to see if he can send me a new head.
Huh. For me that would be a valued optional feature, please post if you find there’s a way to set that up.
Not that it should always do that, but for pedestrian safety in crosswalks I do that “strobe on … stun oncoming drivers …. scuttle across the street …. strobe off ….” a lot.
That’s the default. It remembers which strobe was used last, so a “click, click, hold” from off goes back to whichever strobe-group mode you left it in.
For street-crossing purposes, the bike flasher is probably appropriate… and it can be accessed from off within about a second if it was the last strobe-group mode used.
is the MCPCB on the FW3A fixed in place? Do I need to worry about anything when unscrewing the head? If the retaining ring is tight, do I need to worry about anything? We shouldn’t have to worry about taking the tailcap off, or changing cells, or, or …… in my opinion. I don’t worry about that on any other lights I have.
The mcpcb is not fixed in place, there are no anti rotation screws.
Head is fine to unscrew.
The tail cap should not be unscrewed.
Change the battery by unscrewing the head.
BTW, the optics and mcpcb are only effected if you try to unscrew the bezel on the head, which is not recommended. This is seperate from the head itself. You might be confusing these two things.
Nothing to “worry” about. Just keep it tight & leave it alone. If you do take it off, put it back on and tighten it… as with any light.
Not a thing to worry about here either. Take the head off, change the battery, put the head back on, tighten the head.
Not sure what you mean in this one???
Nothing to worry about in the FW3A either.
A mountain is being made of a molehill by some concerning the FW3A.
It is the same as any other light:
If the tailcap in not tight…… it will not work.
If the head is not tight…. it will not work.
If you put the battery in correctly…… the light will work.
Sometimes a True DOA happens.
As with any light, if you remove the bezel & the MCPCB is not fixed; when you screw the bezel back on if the MCPCB &/or Optic turn with the bezel… a wire may well be pulled loose.
If the bezel is fixed on a light and certain type centering rings turn while tightening the bezel…. the LED may be sheared from the MCPCB.
This is just all normal stuff that applies to ANY light, nothing more.
