If the button is easy enough to press, you might be able to grab the sides of the head with thumb (under) and middle finger (top) and use the forefinger to press the button. Maybe. I can see how the button works best on the end from a design and manufacturing point of view, since there’s likely room for it to be recessed and the overall appearance is cleaner. It also gives access down the axis of the tube, which might be useful during assembly?
Meanwhile I have also received my SP40. It's nice of Sofirn to include the 18350 battery tube. However, I also asked Sofirn to forward some suggestions to improve the UI, e.g. a hidden moonlight mode (long press from OFF) as well as a better configuration for the indicator LED. As far as I was told, they will forward my feedback to Barry.
nice shorty light.
if it have moon mode around 1 lumens + ramping UI then im all over it
too high, it should be 0.3-1.0lm certainly not more then 1lm.
Thank you!
And the Sofirn SP40 headlamp kit are available on Amazon US, get one with 30% off code NOW! Please PM, if you are interested.
More information, please check this amazon link: Sofirn SP40
By the way, thank you all for comment your thoughts and suggestions. :+1:
We appreciated it a lot.
I confirm that the button light always stays on. It's pretty bright, so some people may feel distracted/disturbed by it.
[quote=Sofirn]
We appreciated it a lot.[/quote
Please make it happen and I will buy a couple
I’m sure it will be hot sale if u listen to customers.
Yeah, looking forward for a dedicated,modern headlamp that one day will be most wanted…
Sorry for the delay… here ya go.
Seems like this is a winner over the Convoy. But, I have my Lumzoo and a Boruit D10, and I already don’t use them
Wait, why is regulation on high mode quite poor?
I didn't catch that, but yes. It looks like a thermal throttle at first, but I can't figure out why the output continues dropping past 300 lumens. I'd expect the battery, at 3500mAh, to last longer on high. Maybe not, though.
Do we have to ask gchart for a temperature vs. voltage vs. output runtime graph now? })
Yes, and bypass the springs if possible.
The driver may see a lower voltage drop that way.
On high, it shouldn’t be a problem, but on turbo with active cooling(running), should help.
That’s a bit much (I didn’t measure voltage), but here’s what I’ve got. Realistically, Turbo and High are the same thing except for the first few minutes, you get an extra burst in Turbo.
I haven’t done a disassembly yet, but it sounds like that might be in order. I’m curious as to what kind of driver this is using (linear, buck, or current-limiting resistor). Based on those curves, I’m almost wondering if it’s just a current-limiting resistor. :question:
Yes, that seems like it.
Maybe that’s why they were able to get to a lower price point than almost all headlamps.
They saved 1-2$ by making a simple driver.
Thank you very much. Very useful information! I think the Sofirn SP40 really needs a 300Lm mode. The temperature of the flashlight housing at 300Lm is quite comfortable.
But they already have XP-L drivers in a wide array of products . I guess BOM is more relevant, though I question whether this choice could save more than $1 per unit. It seems silly to make this trade-off, but it would help explain why the price is so low.
gchart’s SP40 charts make this light look less desirable, but not worthless. The overall runtime is okay if you don’t mind the constant fall-off.
Here’s one he made for the SP32A v2, which uses the XP-L2:
Do you have to use the head strap that goes over the top of the head? Is that removable?
Nope, it works great as right angle light (without strap). Check the pictures in the OP. Even comes with a sturdy clip.
