sorry ,i dont have extension tube
5.93€ |17Mm/22Mm Ramping Driver Voor Luminus Sst40 Led|Zaklampen| - AliExpress
Smarter Shopping, Better Living! Aliexpress.com
How about using sst40 shave dome on the l2 ? 200kcd easy.
Hello Simon,
Any news about L2 on XHP35HI ?
Hello Simon!! apart from keeping our pockets empty LOL, is there an interest from your behalf of making a helmet light for mtb or mounted on the front of a bike, thanks!!
I am waiting for the driver with 2 cell for Convoy L2. It works with xhp 50.2 or something similar for about 2400 lumens.
L21A with XHP35 HI will be available soon ,the output current of driver is 2.3A
This would be awsome, but 1000mah is a bit low. You would get better lumems and lux number with a sst40. 2000mah minimum for the 12v xhp35
Thanks Simon, looking forward…
Hi Simon,
Any estimated date for releasing L2 XHP35 ?
DB Custom:Simon, just so you know, Richard at MTN Electronics has designed a Boost driver that works with one or two cells and delivers 2.3A to the XHP-35. This is good for over 2000 lumens in your C8+. Perhaps you should work out a deal with Richard?
For what it’s worth, this same driver of Richards also excels in the L2, amazing lights these 2!
uh ,thanks,i still want to install XHP35 HI in L6,
At present, the design of the reflector is not ideal.
Whats wrong with the reflector? Is the opening to wide and it sits to high? People have done it on here already.
Simon Mao: DB Custom:Simon, just so you know, Richard at MTN Electronics has designed a Boost driver that works with one or two cells and delivers 2.3A to the XHP-35. This is good for over 2000 lumens in your C8+. Perhaps you should work out a deal with Richard?
At present, the design of the reflector is not ideal.Whats wrong with the reflector? Is the opening to wide and it sits to high? People have done it on here already.
although the diameter of L2 reflector is small than L6, but it’s more suitable than L6 ,i campared them several times ,
L2 reflector can get more LUX
Hi Simon,
Driver is in production ,i’m not sure the date
Hi Simon,
I saw l21a on xhp35hi already available ! This is running on single 18650/26650 cell, how about luminosity and distance of the flashlight ? I’m right now ordering it
I thought the L21A runs on 2x21700, while the L2 runs on 26650, or 18650. The M21A runs on 1x21700, and is the 21700 version of the C8+.
Is there a new L21A running 26650?
The L21a runs on 1 single 21700 (i bought one recently)
It does NOT come with an extension tube. (It doesn’t come with any accessories actually, not even a lanyard…)
L21A runs only 1*21700 or 1*18650 w/adapter.
26650 only on L2.
You’re right. I just read the group-buy description again. I don’t understand why, because the SST40 can take 2x26650, which is higher in voltage than 1x21700.
Simon, do you have any indication/comparison numbers of throw and Lumen of the L21a in SST40 vs XHP35 ?
The sst40 is a 3V LED, also the driver is only suited for 4,2V
Sky Lumen has a modded version of the L2 with SST-40 on 2x26650 for 280kcd. If I understand this correctly, it’s a buck driver (DriverVN4), based on the spec of the SST-40 you provided?
