Short review of the review … It looks like you have a good setup there. No flashlight on a large, messy and cluttered table where the attention is diverted from the presented product. Lighting on and around the tested light is superb with few or no shadows that distract. I bet you have a nice collection of flood lights to choose from.
It seems you also have a whole range of heavy quality colored paper, foam or PP corrugated board in nice vivid colors! These backdrops ensure that you look with pleasure at the lights tested and you can purely concentrate on the details, well done!
I'd previously discounted the idea of using the white flat in optics, but it looks like it has its merits. Thanks for this review, and I look forward to your comparison beamshots.
Thanks for your words Grigio!
And…despite it seems I have a great setup, I don’t! I use my kitchen/sitting room to take these pictures! I have 2 lamps that I use and that are the single lamps I have that help me on the review.
The coloured paper are actually individual plastic sheets that can be used to cut some food or to sit a dish if you don’t want to use a table towel! The tint comparison beamshots are made over my travelling suitcase in a small room…
So my conditions are good! Maybe due to that I have to “play with the light” and with the conditions themselves to do the best I can!
Thank you for your words :+1:
Yup, they do indeed! And if they create those “funny” artifacts (that other leds do not create because they are larger or domed) they also allow for a lot of throw. The video I linked above shows hows narrow the beam is and later I will try to show that as well
Hum, this means that the cell maybe have a lower “voltage” than what I actually measured? I am sorry, I may not have understood well what you meant :zipper_mouth_face:
Normally the lights I have with low battery warning have a consistency of warning at almost the same voltage they are supposed to, but this one showed this behaviour. Please explain what you mean :+1:
Thanks for your review. I didn’t even know there was an eco and power mode on my TK16 and of course didn’t know it defaulted to ECO mode. Setting it to power mode makes it a much funner light! Thanks for your UI instructions.
Thank you Hum, I guess this shows how a “pocket thrower” this version with Osram is, right?
On Turbo (Power) it can be seen illuminating at almost 300 m Incredible for a triple light!!!
And I did the “vs FW3A” on purpose to show how different the beams look like !!
Ahah, it has, indeed, and they have different Turbo! In Power group mode, the Turbo is stronger (visibly!) and gets even HOTTER than in ECO mode! So beware of the temperature while using it!
I will be using mine on ECO as it will be enough for my daily use! But It is good to have POWER when you need it :smiling_imp:
I forgot to mention that the TK16 stands and can be a little “candle” when using a diffuser such as the one of the Wuben E05
EDIT:
While the flashlight is electronically locked, if the head is unscrewed and the contact with the tube/battery is broken, the light will then be unlocked !
I guess I understand what you mean now! I had never understand the graphics that way :zipper_mouth_face:
Still, this is a somehow weird thing! And even less pleasant is to have it draining the battery even lower than 2.8V
I will be careful from now on!
I made a lanyard for my Acebeam TK16!
As it is a tailswitch light and the pocket clip is non reversible, I thought of this configuration would be the best to grab the light in a comfortable manner to use it with the tailswitch.
It allows to pick the light up from the pocket by the knot/bead in the tail.
It allows to wrap the fingers with the lanyard in different ways.
The orange thread glows under UV so I can find it in the dark with the RovyVon Aurora A8U without turning ON a “white light”!
There are probably other and better options but I came up with this!
Are you sure that clip is non reversible? … it looks reversible to me.
Changing the battery with the clip reversed would be awkward though since it would scrape against the head unless you used your fingers to lift it slightly.
I didn’t test or calculate the distance, but my eyes saw it reaching at least 200m, as shown in some photos above. More than that, I am not completely able to say concrete data :zipper_mouth_face:
Well, it can be reversible, but it will a) open the clip and force it more, and b) scratch the head.
While with the tip towards the tail it has a “groove” that allows that clip curve to pass without scratching, towards the head it with have friction with the fins! And it will scratch the anodizing.
I should have explained better this before.
If comparing the clip inversion in this light and in the Olight S1R Baton and the On The Road M3 Pro, in these last lights the clip (that has similar shape) will fit much better and without friction with the host!
I didn’t test or calculate the distance, but my eyes saw it reaching at least 200m, as shown in some photos above. More than that, I am not completely able to say concrete data.
Which one has more range: Acebeam TK16 XPG3 or Imalent LD10?
