I’m in please, I’d love for Astrolux to make a tube light similar to the emisar D4 in form factor but also like an Fw3A, so quad, with anduril and 21700 battery with the same rgb aux secondaries from D4 but with tail e-switch of the FW3A
PRETTY PLEASE
I’m in.
Do a 16340 f/l.
I'm in ...
I'm into headlamps so I'd like a high cri light weight , multiple emitter two button usb rechargeable , no strobe ,easy to use interface with lots of options .multiple outputs in each mode ,one throw emitter one flood .
I’m in.
I’d like Astrolux to continue to make affordable quality flashlights for enthusiasts. I like compact designs that use 18650, 21700 and 26650 cells. I prefer 4000k emitters with a CRI over 80.
It rains a lot here in Wales, so water resistance is important to me.
I do not need or want a light that has built-in charging.
I’m in. How about an ultra small ,single emitter, side switch, 18650 EDC.
take a look at the fenix hc65…
worth the money…great alrounder…. Use mine above and below ground… even accidently whilst on a dive(yep was attached to a helmet at the time) nice tints…great throw…
I’m In
I would like Astrolux to make a compact flashlight that is powered by a 14500 / AA battery and runs Andúril UI.
I’m in.
I WOULD LOVE IT IF YOU COULD MAKE A POCKETABLE THROWER (LIKE C8 OR EMISAR D1 SIZE) THAT HAS AN COB LED RING ON THE OUT SIDE RIM FOR A OPTIONAL SPOTLIGHT. HUSKY HAS THIS CONCEPT (whick I will post a link below) but it’s not lithium powered, the tint stinks,not USB rechargeable, etc. I love your products and I believe this would be an amazing unique versatile flashlight that the community would love and would sell like hot cakes. Pm me if you have any further questions!
I’m in
I would like Astrolux to make a flashlight flooder 3* or 4*XHP50.2(4000K and 5000K) & 4*18650 or 3*21700
I would like Astrolux to make a flashlight in the shape of a parallelepiped 2* or 3*XHP50.2(4000K and 5000K) & 2*21700
I’m in!
I would really like if Astrolux makes an upgraded version of the FT03/FT02 with better overall performance in terms of power and throw and better efficiency, also to keep having NW options with decent tints.
Thanks for the great GAW!
I’m in!
I would like to see an Astrolux camping lantern. Something you can use by the picnic table or hang on a tree or inside of a tent.
I`m in.
I’m in, headlamp maybe?
I’m in
I’d love to see the A01 resurrected as an AA/14500 light, but with a 2-stage switch (like the Wuben E-series).
Light twist for low or moonlight, snug for full-on.
Doesn’t need to be a screamer (heat) but a 1-piece tube is a must. Always loved the A01 because of that.
LH351B or -D would be an added bonus.
TIR lens instead of reflector an even bigger bonus.
I am in… I would like to see something EDC, compact and 21700 based.
I’m in.
I would like Astrolux to produce an affordable, titanium 18650 light that is very compact.
I’m in.
Would like an FT03 with the White Flat LED
I am in!
I would like an 14500 flashlight with anduril!
I’m in.
+1 what DAGG3R said -
I’m in.
Make a classy and compact AA/14500 light
