Lumintop Tool AAA Copper + Titanium measurements (Nichia 219B)
10 posts / 0 new
maukka
maukka's picture
Last seen: 4 days 15 min ago
Here’s some data I measured from the two special editions of the Lumintop Tool AAA. My Tool Ti is a Reylight variant with an inverted mode switching (L-M-H). The Copper one is from Massdrop with the stock mode order (M-L-H).
The Ti has been in use for some time, so the tailcap capacitor has had to time to properly charge and activate the high mode. Some interesting findings were made especially in the highest mode. The Ti seems very inefficient compared to the Copper. The problem lies in the driver or the titanium body, since the copper version works well with the electronic tailcap from the Ti.
The copper version is a bit longer at 81,9 mm. Ti clocks in at 73,9 mm. Width is closer at 14,7 mm (Ti) and 14,4 mm (Cu). Copper is of course significantly heavier at 34 g vs. 23 g for the Ti.
The Ti’s electronic switch is flush to the tailcap and very quiet. Straight from the factory, its microcapacitor is empty and the high mode doesn’t work. After a day or so with a battery inside, it is charged.
The Tools lego just fine. Copper body with the titanium tailcap is my favorite to edc even though the other variation looks great.
Measurements
Please note: lumen measurements are only rough estimates
My diy 30 cm integrating styrofoam sphere has been calibrated using a Fenix E05 on high with manufacturer’s claim of 85 lumens. Verified with an Olight S10 that has been measured with a Labsphere FS2 integrating sphere by valostore.fi. Results may be more inaccurate with especially throwy or floody lights.
The Ti has more output at 0 seconds but it steps down after about two minutes to Cu levels. The Copper one has a marginally tighter beam and therefore higher beam intensity (after the Ti’s stepdown). The differences are not visible. There’s no PWM at any level. Copper tool also is significantly more efficient at high. It produces 70 % more total lumen hours on high. On mid the difference is gone. Without a cooling fan the Ti overheats and starts flashing the output at 12 minutes. Copper works much better because of its higher mass and heat conductivity.
On medium the lights are comparable. There’s really no difference in the total lumen hours.
When the Copper Tool is fitted with the electronic Ti tail switch, the efficiency drops just a bit. Even the slightest variation in battery capacity is probably bigger than the actual difference here.
Color rendering (light quality)
For spectral information and CRI calculations I have an X-rite i1Pro spectrophotometer with HCFR for the plot and ArgyllCMS spotread.exe for the data. For runtime tests I use spotread.exe with a custom script and a i1Display Pro because it doesn’t require calibration every 30 minutes like the i1Pro.
Explanation of abbreviations
CCT = correlated color temperature, higher temperature means cooler (bluish)
CRI (Ra) = color rendering index consisting of 8 different colors (R1-R8), max value 100
CRI (R9) = color rendering index with deep red, usually difficult for led based light sources, max value 100
TLCI = television lighting consistency index, max value 100
CQS (Qa) = Proposed replacement for CRI, RMS average of 15 color samples
CRI2012 (Ra,2012) = Another proposed replacement for CRI, consists of 17 color samples
MCRI = Color rendering index based on the memory of colors or 9 familiar objects
x,y = coordinates on a CIE 1931 chart
This is where the Nichia 219B shines. Both lights have a CRI of over 90 and a great neutral white tint. No green/magenta cast anywhere in the beam either as shown below.
Tint and beamshots
Tint in different brightness modes. No visible difference between the lights or modes.
Nice even beam with no discoloration in the corona or spill. Same goes for both lights.
Edited by: maukka on 05/28/2016 - 07:14
The Miller
The Miller's picture
Last seen: 1 year 1 month ago
Very nice review (as always!)
Thanks!
djozz
djozz's picture
Last seen: 1 min 42 sec ago
Great review!
I am really curious where that huge efficiency difference comes from. I assumed that Rey’s version of the Lumintop driver only differs in the firmware which should not have an effect on efficiency. And I was under the impression that exactly the same drivers were used by Lumintop for the copper and titanium Tool.
I have Rey’s version of the Ti Tool too, and my copper Tool is also Rey version. If they show the same performance it is clear that Rey is the source Wink . I have to some AAA eneloops first before I can do the test though.
bugsy
Last seen: 4 years 5 months ago
Great review, thanks much!
M4D M4X
M4D M4X's picture
Last seen: 20 hours 59 min ago
great graphs!
thanks for sharing
 all new deals are also posted here: deals.m4dm4x.com
if you do not find what you are looking for :
ask MARTIN@M4DM4X.COM - i will save you money!
Boro
Last seen: 3 hours 34 min ago
Excellent review, very informative!
thank you
MAD777
MAD777's picture
Fantastic review!
I have the aluminum TOOL with XPL-HI and love it. Now this has me wanting a copper TOOL with Nichia.
Mike
keengeorge
Superb review!!  smile
Thank you Very Much,
George
Geuzzz
Geuzzz's picture
Last seen: 2 hours 15 min ago
djozz wrote:
Great review!
Necro post Smile Have you ever done this test? I have a ti tool on the way and I am very curious.
jon_slider
jon_slider's picture
Last seen: 5 hours 58 min ago
more efficiency tests
http://budgetlightforum.com/node/52650
bottom line, if you get 30 minutes on Max you have the inefficient driver (most common)
if you get over 45 minutes on Max, you got lucky
WTB Lumintop AAA Copper Tool
"High CRI Lights for Sale":https://budgetlightforum.com/node/75426
also happy to share info to help you learn to mod your own..
