6.16 + 5.85 to ship =12$
if you buy 5 they are 30.80$ and free shipping
or you can buy other stuff to get the order above 25 $ to get free shipping
I have a bunch of the tenergy NIMH D's so there is no leaking in lights anymore
Shipping Weight: 1.45 pounds
True to its name, Rayovac Roughneck lights are tough and durable. When you need a light that works as hard as you, the Roughneck line will get the job done. With high performance LEDs and standard lifetime warranties, we’ve got the professional level lights for the work you do. Rayovac is a trusted brand of Spectrum Brands Holdings, Inc., a top manufacturer of consumer batteries in the United States and Latin America.
True to its name, the Roughneck is the toughest, most durable flashlight Rayovac makes. With a shock absorbing bulb system, it withstands a 7-10 foot drop test, has spot-to-flood focus capabilities and is water resistant.
WOW ipx 4 .... what is that ?? splashed from the baby ppol or squirt gun from 3 feet
I have Amazon Prime account so the shipping was free so, that made the decision for me . I never thought about those batteries before......humm
Thanks
IEC 529 European (ECC) Water Protection Specifications
IPX# waterproof specifications are specified on instruments and equipment. Below is a table of waterproof test level definitions based on the IEC 529 Specifications.
Water Level Definitions
IPX-0-0 | No special protection |
IPX-1 | Protected against falling water Equivalent to 3-5mm rainfall per minute for a duration of 10 minutes. Unit is placed in its normal operating position. |
IPX-2 | Protected against falling water when tilted up to 15 degrees - Same as IPX-1 but unit is tested in 4 fixed positions - tilted 15 degrees in each direction from normal operating position. |
IPX-3 | Protected against spraying water - Water spraying up to 60 degrees from vertical at 10 liters/min at a pressure of 80-100kN/m2 for 5 min. |
IPX-4 | Protected against splashing water - Same as IPX-3 but water is sprayed at all angles. |
IPX-5 | Protected against water jets - Water projected at all angles through a 6.3mm nozzle at a flow rate of 12.5 liters/min at a pressure of 30kN/m2 for 3 minutes from a distance of 3 meters. |
IPX-6 | Protected against heavy seas - Water projected at all angles through a 12.5mm nozzle at a flow rate of 100 liters/min at a pressure of 100kN/m2 for 3 minutes from a distance of 3 meters. |
IPX-7 | Protected against water immersion - Immersion for 30 minutes at a depth of 1 meter. |
IPX-8 | Protected against water submersion - The equipment is suitable for continual submersion in water under conditions which are identified by the manufacturer. |
So rain proof. Not bad.
Got mine today too and am happy with it. The rubber protection around the head, tail and along the body make this a perfect light for the kiddos. Everything about it feels very sturdy. Thinking about ordering some for the cars too and just leaving them in the packaging so I don't have to worry about battery leak lol.
I bought 4 and these are great as Christmas presents, white elephant games. Yep, Christmas is coming soon.
Got some this morning...thanks for the heads up.
Mine came today. Not a bad worklight, but the beam is ringy as heck. It's worth $10 as a knock-around, short-range light. It is not going to replace an L2 or even a Maglight.
The biggest thing to dislike about it? #%$ *&@! CLAMSHELL PACKAGING. JEEEeeeeez, I wonder how many people get cut or injured trying to take things like this light and batteries out of the clamshell. I HATE that stuff. Had to use a serrated knife to get through it, put a nick in the body of the light when I did it.
BTW, this $6 light is almost exactly the same size as a TK41, just little thicker body. Very comfortable to hold, especially with the rubberized inserts.
It is an XP-E with some sort of moving-aspheric that is part of the flood-to-throw mechanism.
Edit again...the throw on this light is not too bad. Puts a very cool white hotspot out about 150 feet pretty clearly.
Or you can use one of those snap-off razor knives with the adjustable blade length . Just leave about 1/16 of the blade showing .
i use tin snips
No i'm pretty sure you need to use whatever exduct knife they just sent you ..:P
So is this light ,Not ringy at some setting ?? has anyone torn one apart yet ?
Haha, like I said...why should you need access to tin snips to open a *&^%ing $6 flashlight? Hazardous and environmentally unfriendly, clamshell should be banned from the planet. Every year 6000+ people end up in the emergency room due to injuries caused by clamshell wrap.
Has anyone tried these "2*AA to D Battery Adaptor Converter cases"?
http://www.ebay.com/itm/270819252873
On the back of the packaging there's a perforated tab that you can pull for bladeless opening. Worked for me at least.
Ahh, I didn't even see that.
Impatient me....
Gotta be smarter than the packaging
I was also decently surprised by the spot it threw after testing it in the dark. The flood appears to go much wider than my maglite too.
I just ordered three more for gifts -- the metal body really is quite nice.
thanks for posting this deal. Picked up 5. One or two for myself and will gift the others.
