Deep stepdown to 400lm after 90 seconds when the head is under 100 degrees F. I think there’s lots of room to improve. The driver for the BLF A6 steps down after 45 seconds on turbo, but goes to around 1000lm so it’s more reasonable.
Any idea if the USB port is waterproof without the flap?
I haven’t disassembled it yet to say for sure, but I don’t think it is. The flap seems to seal really well though so I’d be comfortable with it around water (just not diving of course).
I like to snorkel with my lights, and I have a light that gave up on me on the first day of my vacation, so now I’m being a bit more careful
I guess I’ll skip this one, flaps make me anxious.
That eliminates most all lights with on-board charging. There’s a couple with charging in the threads but those are few and far between.
I have one of them - JetBeam BC20-GT.
Olights also have magnetic charging, few others as well.
Ahh yes, I forgot about magnetic charging. That’s a good solution if you plan on a light being submerged.
Not usure how or how tightly Wurkkos and Sofirn are tied. Best case, the presence of (real?) USB-C charging means Sofirn will adopt it soon.
They’re either closely tied (I think so) or use the same ODM. The head of the FC11 and SC31B seem have come off the same production line. I haven’t tried it yet, but I wager that they Lego.
Will you post beamshots or some shots outside?
Thanks for the review.
Can you reverse the ramp in the middle of one direction by pressing the button once to stop the ramp and quickly again to go the opposite direction, like one of my Sofirn lights, or do you have to go all the way to either the top or the bottom to reverse direction?
I prefer to be able to change ramp direction anywhere in the ramp process.
I just confirmed… yes, you can definitely change direction mid-ramp like you’ve described. The ramp itself is relatively fast, seemingly especially so at the lower end (unfortunately).
Here’s a couple beamshots with a Sofirn SC31B SST-20 4000K (95 CRI) for comparison. Side by side, the FC11 was noticeably more floody and brighter… as you’d expect. The LH351D has a larger die area and has been shown to put out more lumens vs the High CRI SST-20’s.
Ceiling, FC11
Ceiling, SC31B
Outdoors ~25yds to the woods, FC11
Outdoors ~25yds to the woods, SC31B
Thanks gchart for verifying the ability to reverse ramping direction at any time and adding the beam shots.
I just ordered one with the discount.
This UI appears to be identical to my Sofirn SP32A V2.0, which I like pretty well, but it’s switch is too easy to activate accidentally, so it gets daily use on a counter where my chargers are located in bezel up position for use as an area light, rather than in my pocket.
This Wurkkos FC11 will potentially replace my BLF A6 3D as EDC clipped inside my back pocket, since it’s got a high CRI LED with a large hot spot. I really like the beam and tint on my A6 3D.
No problem!
Any suggestions for a deep carry clip for this light?
I’ll evaluate the clip from my A6 for use on the FC11 when it arrives, but would like to know of other options.
Thanks.
Not sure, honestly. Let us know what you find out.
I wonder if Match’s idea would work. Instead of drilling, could the wire be threaded through the lanyard hole on the tailcap?
Another idea I’ve used it to tie a paracord lanyard approximately as long as the knife/light. Leave the lanyard out of the pocket, and it holds it at the right height and makes it easy to remove.
Can the battery tube of the FC11 be interchanged with the SC31B? This would likely mean the Sofirn 18350 tubes could also interchange.
I haven’t tried every lego combination, but I’m going to say yes. I can try more interchange combinations tonight.
I’ve tried swapping the tailcaps and it works fine (helpful if you want to swap magnet for no magnet). And the heads (excepting the bezel/reflector which is longer on the SC31B) look like they came off the same assembly line.
Good thought on the short tubes. I might have to pick some up… I’ve got a couple nice Shockli 18350’s sitting in their wrappers unused. I sold my only 18350 lights.
