Will you post beamshots or some shots outside?
Thanks for the review.
Can you reverse the ramp in the middle of one direction by pressing the button once to stop the ramp and quickly again to go the opposite direction, like one of my Sofirn lights, or do you have to go all the way to either the top or the bottom to reverse direction?
I prefer to be able to change ramp direction anywhere in the ramp process.
I just confirmed… yes, you can definitely change direction mid-ramp like you’ve described. The ramp itself is relatively fast, seemingly especially so at the lower end (unfortunately).
Here’s a couple beamshots with a Sofirn SC31B SST-20 4000K (95 CRI) for comparison. Side by side, the FC11 was noticeably more floody and brighter… as you’d expect. The LH351D has a larger die area and has been shown to put out more lumens vs the High CRI SST-20’s.
Ceiling, FC11
Ceiling, SC31B
Outdoors ~25yds to the woods, FC11
Outdoors ~25yds to the woods, SC31B
Thanks gchart for verifying the ability to reverse ramping direction at any time and adding the beam shots.
I just ordered one with the discount.
This UI appears to be identical to my Sofirn SP32A V2.0, which I like pretty well, but it’s switch is too easy to activate accidentally, so it gets daily use on a counter where my chargers are located in bezel up position for use as an area light, rather than in my pocket.
This Wurkkos FC11 will potentially replace my BLF A6 3D as EDC clipped inside my back pocket, since it’s got a high CRI LED with a large hot spot. I really like the beam and tint on my A6 3D.
No problem!
Any suggestions for a deep carry clip for this light?
I’ll evaluate the clip from my A6 for use on the FC11 when it arrives, but would like to know of other options.
Thanks.
Not sure, honestly. Let us know what you find out.
I wonder if Match’s idea would work. Instead of drilling, could the wire be threaded through the lanyard hole on the tailcap?
Another idea I’ve used it to tie a paracord lanyard approximately as long as the knife/light. Leave the lanyard out of the pocket, and it holds it at the right height and makes it easy to remove.
Can the battery tube of the FC11 be interchanged with the SC31B? This would likely mean the Sofirn 18350 tubes could also interchange.
I haven’t tried every lego combination, but I’m going to say yes. I can try more interchange combinations tonight.
I’ve tried swapping the tailcaps and it works fine (helpful if you want to swap magnet for no magnet). And the heads (excepting the bezel/reflector which is longer on the SC31B) look like they came off the same assembly line.
Good thought on the short tubes. I might have to pick some up… I’ve got a couple nice Shockli 18350’s sitting in their wrappers unused. I sold my only 18350 lights.
Kinda like this?
Using the BLF A6 deep clip it will disappear into your pocket.
Want it smaller? Use the tailcap from Wowtac A3
These Sofirn 18350 tubes fit lots of different flashlights, Get you Some!
Later,
Keith
The 18350 tubes aren’t available on their own anywhere, are they? I checked Sofirn’s Aliexpress store and didn’t see any. Perhaps we can see if they’ll add them.
EDIT: scratch that, I see 77outdoor has them on Amazon. I wonder if anyone else has them? I still feel like it’s something that Sofirn should have an Ali listing for.
I just got mine t’other day, but haven’t tried legoing anything yet.
It’d be nice to remember wherenahell I put my 18350s first…
Here ya go, best price on sale now 2 for $1.49
Free shipping over $19 order.
The ones on Amazon still get shipped from China.
Ordered a few more sets last week and they shipped with tracking in about 4 days.
Ahh, thanks Keith. I forgot they had their own storefront now. $1.49 for 2 isn’t bad at all (+$1.99 for shipping if your order isn’t over $19… still not too bad).
Got this light today. So far looks great. I feel like this is the best light at this price. I’m a big fan of the LH351 though!
It really is a great light, especially for the price. I’m kinda surprised I haven’t seen more posts/threads about it.
Yeah, I did a quickie review, got a couple of one-liners, and that was it.
Surprised, being that it’s quite a nice light. Thought it would’ve made more of a splash.
