I remove them with a soldering iron and small flat screwdriver. While lightly prying up with the screwdriver, run the iron up and down the legs on one side until the lift up. Then grasp the MCU with tweezers and then run the iron on the other side to lift it up completely. It’s not too bad.
But are you shure these XHP50.2 are real 5000K emitters?
Do you have an order code or exact binning of these emitters?
I have bought some of them from cutter.au binned in 3B color tint and they are warmer and less green than on my Astrolux EC01 5000K, which is produced in your factory.
My browsers and router do not like your new website-
Warning: Potential Security Risk Ahead Firefox detected a potential security threat and did not continue to sofirnlight.com. If you visit this site, attackers could try to steal information like your passwords, emails, or credit card details. What can you do about it? The issue is most likely with the website, and there is nothing you can do to resolve it. If you are on a corporate network or using anti-virus software, you can reach out to the support teams for assistance. You can also notify the website’s administrator about the problem. Learn more… Websites prove their identity via certificates. Firefox does not trust this site because it uses a certificate that is not valid for sofirnlight.com. Error code: SEC_ERROR_UNKNOWN_ISSUER View Certificate
Yeap. Saw it the other day and had to do a double take. Pretty cool. Hope they adjusted the thermal settings for the q8. Wish they added built in charging though.
I’ve read that there are some flashlights that use versions of Andruil made for other flashlights, so they may end up having an early drop off from turbo without the light getting warm? I guess you could go in and reconfigure it afterwards. Just wondering how much they tested with the settings specifically for the Q8.
TK already had special config files for the Q8 with the proper thermal settings. Of course that doesn't mean Sofirn actually used it, but hoping Barry got the firmware from TK directly for the Q8, so would be guaranteed.
Yea, best I can tell, Sofirn has previously sold only 2 Anduril lights: The SP36 and LT1. Most likely 1 of 2 possibilities:
they used the SP36 firmware on the Q8 as-is
or they got the latest Anduril build from TK specifically for the Q8
Her thermal regulation algorithms are tweaked according to how the host can handle the heat - basically will it react faster or slower. The FW3A needs fast response because there's not much thermal mass considering the amps/LED's, while the Q8 has decent amount of mass for it's amps/LEDs.
However, I’ve been rewriting all the thermal code (and voltage and ADC) over the past couple months, because some changes I made in November made the thermal response get a bit weird. Basically, I did a pretty large rewrite to fix some bugs which had been hanging around a long time, and the rewrite messed up the thermal behavior on some lights. So I rewrote that too.
I’ve finally got it at a point where it pretty much “just works” on every light I’ve tried it on, whether that’s a tiny hot rod or a large and more moderately-driven light… whether it’s 1, 2, or 3 power channels… and whether it’s regulated or direct-drive or a hybrid.
Anyway, here are the test results for a BLF Q8:
It may look odd, but the curve is pretty close to ideal for this type of light. It could be a little smoother, but the jagged parts aren’t actually visible during use. Each adjustment is pretty slow and gradual, and only looks steep due to the amount of time which passed during measurement.
The output gets higher as the voltage drops because of how linear drivers work. When the input voltage is high (full battery), there’s a big difference between that and the output voltage, so the difference is burned off as heat. But when the two voltages are close together (low battery), there’s less heat and it can instead produce more light. So it gets brighter as the battery drops, because it’s attempting to maintain a constant temperature.
During the entire graph, output sags over time because it’s running direct-drive, and if it was water-cooled it would produce a curve identical to the battery’s discharge curve. Basically, it keeps sagging more and more quickly as the charge drops. The algorithm then fights against that to keep output and temperature from falling too much.
Then near the end it reaches its highest level and the direct-drive decay curve takes over until low-voltage protection kicks in.
The code isn’t published yet, but that should be resolved very soon because I’m nearly done running tests.
I don’t consider it “stable” yet because it hasn’t had much testing… but if you don’t mind using brand new versions which have large and not-widely-tested changes, they’re on my dev builds page.
