Ok, here’s the same light i think - AMAZON
Being sold as the same ‘pure copper’ light
BUT in description - ★Strong light long-range flashlight, high brightness, long range, large capacity, long battery life, aluminum alloy body, field, cycling, lighting, home, maintenance, etc., all meet your needs
I asked the store to send me pictures of the actual flashlight
They was nice and said no problem , sent it to my email
I m not sure it’s even brass though
I think it’s probably titanium, coated in copper then brass - finished off with a sleeve of aluminium in a luxurious gold anodised finish.
G0OSE thanks for finding that.
That Amazon listing has a lot of technobabble in it.
But yes it does list “aluminum alloy body” as you point out. (Should say aluminium for the UK, no? )
It also lists the weight as 131 grams. That would be too heavy for an aluminum host alone. My brief search on BLF tells me an aluminum S2+ is 81 grams. Unless they are including the battery in which case that would be right on for an aluminum host with an 18650.
They are including a battery and charger !
the amazon link also says the light is a Zoomie, with large astigmatism…. and other nonsense:
★ Mechanical telescopic focusing, astigmatism, eccentric adjustment, eagle-eye spherical resin concentrating mirror, high transmittance, large astigmatism
Material: other
Color classification: pure copper flashlight
Has anyone noticed on the AE Shenzhen A plus Lighting Ltd Store the estimated delivery date of this brass color S2+ clone?
May 9th,2020
The Amazon UK seller lists it as In Stock
Brass pill or driver shelf?
That’s what I’m afraid of!
Basically it’s anyone’s guess - who’s ordering to find out lol!
If anyone wants to order it I can help him with a $10 coupon
Ahh what the heck. Just ordered it.
I’ll definitely post my findings once it arrives.
Stay tuned until May 9th I guess.
Well I think about ordering it…
But from picture I am 90% sure it’s gold colored alu
Or just Chinese copper.
yup
and the weight is correct for aluminium
congrats, I hope you enjoy it
here is another (copper) light from your link
https://www.aliexpress.com/item/32718131525.html
the number of contradicting statements in the description, boggle the mind
“Purple Bronze, 300 lumen, reverse clicky, tailcap twisty”
looks a bit like a cross between an Eiger and a Sapphire
how can I resist? LOL
(easy, just step away from the keyboard)
is really copper? it looks very yellow ? its probably just painted yellow and not true copper with the extra weigth…
they just trick people inte believing its pure copper… its 99% not…
Correct me please if I am barking up the wrong tree:
The ratio of mass densities of copper/aluminum = ( 8.96gm/cm^3) / (2.73gm/cm^3) = 3.28
If an aluminum S2+ is purported to be 81gm, then a similar body in pure copper should
weigh approximately: 81gm x 3.28 = 265gm?
If 131gm is purported to be the weight of this “pure” copper light, it
Most probably taint copper.
Bamboozled. Mashugganahs.
You mean Chopper?
Like eating is proof of the pudding, weighing is proof of the material.
A ratio of 3.28 is a bit too steep, for an aluminum light has parts that are not aluminum.
And those are the same parts that are not made of copper in a copper light.
Anyway, my copper C2+ (1st.edition) weighs 175g without a battery, and 222g with a 30Q.
So 131g could be a thin-walled copper light without battery, or an aluminum light with battery.
Sorry to re-enstate the (remote) possibility this light is actually a copper light.
The knurling looks nice. This light looks less lego’d together than an s2+.
Henk, is it possible your copper S2+ may also be made from a copper alloy,
not
From pure copper? Cost effective? Better thermal properties? A better profit margin?
BTW, can we assume the electronic components of both the Cu/Al are similar, so
Cancels out.
Cheers, Heineken
