Those Knipex at $53 discounted are a big investment, but might be worth buying if I had other uses. But they look like a smooth finish jaw so not sure if they can hold the MCPCB very well.
I got a few locking pliers types, but again not sure bout the teeth and adding cushioning. Some have teeth that are too big, or deep teeth that are hard to cushion. I'll have to see.
We call tongue and groove pliers “Channel Locks” and locking pliers “Vice Grips,” though that might not be the real names. Never heard them called anything else, but a rose by any name would smell as sweet.
I actually just used a pair of channel lock/tongue-and-groove pliers for the first time today for swapping a boat trailer jack… I’m buying some ASAP. SO much faster than setting an adjustable wrench.
We usually call them slip-joint pliers…. sometimes channel locks. Never heard tongue and groove tho(except for flooring and other wood products) Not sure how big the piece you are trying to hold but I use hemostats(medical pliers) for holding small stuff…… works really well.
I tried that before as well while shrinking a MCPCB from 20 to 10 mm. After adding cushion to the jaws they wouldn’t keep it securely. Maybe a different cushion material would work better but that’s what I came up with quickly.
A double click on the button should ramp down the light from x (high) to y (off) gradually. Removing the finger from the button should stop the ramping somewhere between x and y.
Mine doesn’t do this. It is either on or off. Does this mean that the circuitry is shot? Is it resettable/repairable or have I just got a single mode torch/flashlight?
What’s the state of development on LEP? Do folks here think it’ll be a killer of LED-throwers? Might some makers combine an LEP (throw) with LED (spill) for the “near perfect” flashlight?
I've known them as channel lock pliers, but that's a brand name apparently. A quick google for either term gives a good idea.
Sorry the Knipex were half-joking. They are expensive, but an interesting alternative to a crescent or adjustable wrench. They are a particularly expensive example of a Knipex wrench - however, my Knipex tools are my nicest tools by far. I am sure they will outlast all my other tools, and me.
Please don't use those on nuts/bolts! Anything with teeth should stay far from nuts and bolts.
Slip-joint! Yes, heard that term as well. As for hemostats... Forceps to me! I use forceps routinely when soldering - it's a tricky thing to keep them from buggering up the wires.
What type of cell are you using? Alkaline, NiMh/NiCd, Lithium Ion, Lithium Primary?
