I sent a PM. Does anyone know how to affix the filter to the outside of the lens? I want to use some on a Wurkkos FC11, I can get that one apart and put filter behind the lens. But what about on lights you can’t get apart?
I assume mbp is talking about the color filter rather than the diffuser, personally I used tiny amount of glue from a glue stick around the edge. It works ok but a water resistant glue might be better.
Not to rain on this. How are you keeping the gel from melting? Multiple times I have had issues with small camera flashes melting them. Cost me a ex580, and I became much more selective about when I would use them.
It’s optically clear and cured with UV. Usually used to attach tritium vials, but it might work to bind the two layers together without artifact or marking?
If you’re using a crazy hot rod flashlight Then I’d suggest using the zircon filters which are tough as nails . You’d have to be running a welding torch to burn one up .
Never heard of anyone melting a regular filter with a flashlight but obviously Lee wanted or felt the need to also make a tougher filter too. :)
Once mine come in I’ll be posting pics of my Astrolux ft03 xhp50.2 6000-6500k (dedomed) before and after. I don’t have pics of beam before I dedomed, but the cct dropped which was great but also got MUCH greener, this should help ALOT.
yes I’ve recently gotten new filters in ..Including the Zircon 805 which has always been the hardest one to find , as well as some of the Rosco filters . ... and about a dozen different diffuser film sheets .
PM me and I’ll send you an up to date list of everything I carry .
