I assume mbp is talking about the color filter rather than the diffuser, personally I used tiny amount of glue from a glue stick around the edge. It works ok but a water resistant glue might be better.
I tried using 3 small dots of super glue to attach a minus green filter to dc-fix 1. It left some ugly marks on the filter and bezel.
I also tried Elmer’s Clear glue and that didn’t hold.
Are there other suitable glues?
I wonder would it be possible to install with a bit of water between the film and the glass, similar to some smartphone protective films?
Manker E14III NW with #F1 1/8 minus green filter:
Green almost completely gone on low.
It doesn’t look green on Medium/High/Turbo now. :+1:
Glad I could help ...
No one wants a green light except maybe the Green Lantern .
Not to rain on this. How are you keeping the gel from melting? Multiple times I have had issues with small camera flashes melting them. Cost me a ex580, and I became much more selective about when I would use them.
How about Norland 61 ?
It’s optically clear and cured with UV. Usually used to attach tritium vials, but it might work to bind the two layers together without artifact or marking?
If you’re using a crazy hot rod flashlight Then I’d suggest using the zircon filters which are tough as nails . You’d have to be running a welding torch to burn one up .
Never heard of anyone melting a regular filter with a flashlight but obviously Lee wanted or felt the need to also make a tougher filter too. :)
Yassss,
Was looking for this all over amazon and ebay. I need this for my E14 III BLF combo. It quite too green for my taste. PM sent, thanks Boaz.
Once mine come in I’ll be posting pics of my Astrolux ft03 xhp50.2 6000-6500k (dedomed) before and after. I don’t have pics of beam before I dedomed, but the cct dropped which was great but also got MUCH greener, this should help ALOT.
Thanks, Boaz! pleasure purchasing with you
Is this still available?
Yes .....
In fact I have new / harder to find zircon sheets ....as well as more regular Lee and Rosco filters
I have about 15 different filters and another dozen or more diffuser films available .
PM sent
thanks
PM’d. I’ll update with how it goes.
Edit 2/13/21: I got the sheets, they look great. Awesome price, and they came with a nice note. Can’t recommend enough.
Thanks Twin8 ... Glad I could help .
Appreciate your kind comments
Are these still available? Looking to buy some of the Zircon minus green filters to help with the green tint on a light with 5000k SST-20 LEDs
yes I’ve recently gotten new filters in ..Including the Zircon 805 which has always been the hardest one to find , as well as some of the Rosco filters . ... and about a dozen different diffuser film sheets .
PM me and I’ll send you an up to date list of everything I carry .
Thanks Boaz
I sent you a email to the address in the message you sent me. I’m unable to PM you back, probably because my account is too new. Let me know if you got it!
Interested in a few zircon filters as well. PM sent
PM sent. Thank you, Boaz!
Thanks Light Saber...
I sent you my standard reply with a wall of cut copy and paste text canned reply to requests . Info on everything I offer is in the PM reply .
Anyone wanting more info just PM me .
I'll get info on both diffusion film and the minus green filters your way ..
