【convoy】H4 and B35AM options are updated
The flashlight hosts are almost completed.
Next, the manufacturer will start to produce 18A drivers. Considering the matching problem, some adjustments may be needed.
I’ve just measured that for you, it drops 110 Lm after that it’s pretty stable and doesnt drop very hard anymore
That’s higher than what I was able to achieve on 3 of mine.
I got different readings for other set ups too. These are all different chips of the CULPM1
7A - 1313 & 8A - 1318 (same chip)
7A - 1260
6A - 1300
6A - 1200
Just shows how much variation these Osram chips have.
On the datasheet for the 8RF bin, Simon sells, has got a Min 1690 lm and Max 1900 lm at 6A
Matching problem? BTW, I’m very excited about this light!
Just dropped in (last couple of pages). 3 x 21700 light picks my curiosity.
Any rendering or some info?
Likely very similar style to the 4x18a. Though I personally wouldn’t mind a little extra aluminum be left behind in the head at the bottom of the reflector well with deeper fins and a thinner bezel that allows for a larger reflector.
Hello,
please could anyone explain, how does low-voltage protection/warning on S2+ 5000mAh / S21A 6000mAh drivers work?
Is it warning only - starts flashing once voltage decreases to certain level? Or does it also cut off the battery - if so, at what voltage?
Also, how does the driver work? What is the max. current on let’s say 50% load? Does it pull 2500mA continuously? Or “caches” 5000mA then 0 for a while, and so on?
I’ve pulled some ICR18650-26Ds from dead laptop battery (2 out of 9 cells dead), and would like to know, whether I can use them. They are rated at 5200mA max current, but I don’t want to push luck drawing 5A off them. At the same time - they’re not protected, thus my interest in voltage cutoff.
Someone else can chime in on your questions but I wouldn’t use the ICR chemisty, specially old cells. ICR can be dangerous without an added protection circuit.
You’d ideally want to use cells with a current rating of 10A+ for a 5-6A driver current. These flashlights require the highest possible voltage on load, when drawing a high load the voltage will drop and how far that drop is depends on the performance of the cell used. There are other factors but I’ll leave it at that. For a 5A cell I’d advise 3A max load. Get something decent. Note that old used cells have a higher risk depending on how healthy it is. If a cell gets unstable just remember you’re holding a sealed metal tube that has the potential to explode
Just a warning S21B does not go along with 20->22mm adapter from KD. The adapter is too high and you cannot screw the retaining ring. It accepts only genuine 22mm drivers. Until you find lower adapter or you file it down.
rms,
First of all can't say how the driver cut-off works (never experienced it yet), but the word says cut-off, which is self-explaining.
Cut-off in drivers is one of those things which overall needs room for improvement. In my opinion it is overall set too high (read my P.S. in #3881 post here).
There's still too much actual ignorance about li-ion cells, and besides positive beliefs in this matter I have some straightforward experience. Like leaving a couple scavenged ICR18650-26C cells straight connected to a white led with thin wires for many days (with no driver - closest config to a direct drive setup, less resistance and faster result). Consider the minimum Vf of a white led is around 2.5V or close. This means a li-ion battery connected to a simple direct drive, linear or buck driver driving a white led just cannot get overdischarged. Back to my experience, after disconnection the cells climbed well above 2.5V, which is to be expected.
Another thing I can narrate is my latest experience with my li-ion converted hair clipper. Powered by two TurdFire IMR14500 700mAh (LoL!) cells in parallel, weeks ago I noticed them going weak and losing charge quickly (very high self-discharge). Since I needed it, while I ordered and waited for new cells I recharged the appliance every few days. At some point I forgot to recharge it for many days, and when I noticed it wouldn't even turn on or barely move without load. And still, I confidently dared to recharge it. Nothing wrong happened (it still works right and today or tomorrow will give the old cells their last run). Why? Because li-ion batteries need time to chemically decompose at low voltages. Can't say how much, but must be quite lenghty. I know what I'm saying because I also dared to recharge a couple of the above mentioned ICR18650-26C cells from 1.7V or around. It was a pack of 6 from an old laptop battery and I recharged and tested them all without problems. At last I raised all cells to ≈3.9V and observed their self-discharge over a few weeks. Two cells lost some voltage, and so I discarded them. I kept the rest.
But well, you are free to believe as you like - and deal with the results or consequences.
P.S.: On a side note, overall low lifespan for these (now old) cells. Sold better binned and improved also under other wraps: Shockli and Vapcell, for example. Heter is their OEM manufacturer.
Mon, 11/23/2020 - 13:58
Thanks!
Had 4pcs 30Q discharge to 0v and left like that for 4 days, no hope whatsoever in reviving that low.
That’s quite possibly correct what Barkuti says but it’s a different story if a light has parasitic drain in an e-switch. That’s different altogether though, only a protected cell will stop that issue
Funtastic,
0V for 4 days Sammie 30Qs? Well, you can make a test. Recharge them in some safe place to some not too high voltage, observe their self-discharge over a lenghty amount of time, even properly test their internal resistance. If cells still behave normally they could be used. But this is just because of “science”, in practical terms all of the involved effort is worth way more money than the price of a new pack.
I charged them at 300mA but they instantly discharged back to 0v so I binned them. Had a 4X18A driver fault drain them
Ftfy.
I got the accessory sample for lighted switch ,
But there are two shortcomings, the tail is not waterproof, the flashlight loses its inverted function.
That’s not a problem. I’m sure.
Thx Simon
Just received my S2+ with KY CSLNM1.FY Will upload a comparison between a 2700k SST-20, KY CSLNM1.FY, and XP-E2 amber when I get the chance.
i get some samples from Getian company.
12V 4A driver for L6 is in design ,too
Very interesting.
Is the input voltage going to be 2S or is one cell supported too?
