Your skills are impressive
Touch-switch, Anduril, 5mm leds, übercool!
Small update, but it’s an update I guess. I drilled the holes for the LEDs and dry fitted them. Not quite sure what I’ll use to glue them in place… UV-cured glue? Hot melt glue? I’m out of clear epoxy. I’ve got JB weld but that would look unsightly. Probably just the UV glue I guess.
Here we go! Build is finished.
One of the more difficult things that I didn’t anticipate is that this kind of plastic doesn’t take glue very well. Hot glue was a no-go. Original Gorilla Glue fell right off. Gorilla Glue Super (CA) Glue Gel didn’t do any better. I ended up having some success with DAP RapidFuse.
Gteat! Very tidy inside.
Nice work !
Nice result! Anduril for a reading light for the children, that is true BLF spirit
Congratulations for your finished build! Well done.
It is really cool that these 5mm leds are running with Anduril.
Nice build and great video gchart
:laughing: Nice.
Awesome! Great design and creativity using your own design and fusing it with Andruil. You could probably market that as a reading or nightlight.
Thanks guys. The Anduril thing was purely for the fun of it. What would have been much more purposeful is to have it be a simple on/off switch with a fade-out after like 30 minutes (assuming the child will probably just fall asleep with the light on). Sure, there’s sunset mode but I’m not going to encourage the child to tap 3 times then do another 2 taps. I would consider reflashing the driver after the competition, but umm… it’s glued down and the programming pads are on the glued-down side. Oh well, it works just fine. If she’s has problems with it, I’ll rip the driver out and put in a new one.
Great job gchart on your build. I love to see your electronic experience in action.
I am always learning from your posts how to wire things together, Thank You for all your contributions here at BLF.
Nice work !
I watched the video and truly laughed out loud when I saw you ramp the light up. The use of Anduril on such a light is, to me, the cherry on top for a BLF competition.
Cross-posting from the “What did you mod today?” thread. This is NOT part of my build, I’m just building on my build.
While that touch lamp for my contest entry is cool and was fun to build, it’s really not feasible for my kids to use (Anduril) and it’s not very reproducible. So I decided to create a functionally similar, yet more more simple & sturdy version. I designed a new housing with Fusion360 and printed it on my 3D printer using PETG (after a couple revisions to get all the dimensions just right). I designed a simple circuit board in Eagle and sent it off to Oshpark using their After Dark service. I’m also using an off-the-shelf TP4056 charging board with protection features. I’m still amazed at how simple, cheap, efficient, and configurable these TTP223 touch sensors are! Put that together and I’ve got a nice compact very simple on/off touch lamp with built in charging.
This is awesome. The wiring is also neat and pretty.
Very nice outcome, and the green puck is the best!
