It’s really personal preference and we don’t have real data of their performance under this new reflector. Personally, I prefer the W1.1 since FF told me they searched hard and was able to procure the very hard to find 6Q flux bin for the already rare CULNM1.tg, which is the W1.1 not the standard W1 other manufacturers are using. This is the highest I’ve ever seen on the market. It is listed as the 2nd highest bin but as with most LEDs, the highest bin listed is a paper spec only and don’t actually exist.
I don’t know what flux bin their CULPM1.tg (W2.1) is but I prefer W1.1 over W2.1. If I want high output thrower, there is the SBT90.2 version that should have similar throw to the W2.1 but several times the output. Also IIRC FF was able to find the SB flux bin for the SBT90.2, which is higher than the RB and SA bin that I’ve seen sold on the market. The SB is the highest “available” on the market and I only seen it used in the Noctigon K1.
These new OSRAM's do have names and they are really easy to use and remember:
4040 Part # Name size
CULNM1.tg Boost HL 1 mm²
CULPM1.tg Boost HX 2 mm²
680 kcd on the Boost HL is a really good # compared to what should be a bigger reflector in the K1, rated at 650 kcd on the Boost HL. So between the possible better binning and maybe more amps (??). But these are all specs, not independently tested.
This T9R has a 64 mm head diam while the K1 has a 72 mm head diam.
I’m surprised FF went the total opposite direction on tube length. If this light supports 76.5mm batteries I would be surprised if it makes good electrical contact with a high drain low resistance flat top which would be bad for 90.2 version especially.
What makes a USB-C protected battery vehicle friendly if the light already has USB-C? It provides no protection for a battery just sitting in storage that i’m aware of.
Sorry for confusion what I meant by vehicle friendly is it’s chargeable on the go via car port
… then again can always carry extra batts and a charger along on trips
Edit: Contractor I see what you’re saying, Samsuck 21700-40T is even shorter than-50E @ 70.30mm… Loose cells no good. Maybe the 6mm taller USB Batt is pushing hard on the springs?
The original lights were designed to be as compact as possible and had issues with longer cells. For me the biggest issue I had with the BeCu springs is that they did not have good resilience (recovery) and if forced too tight, they no longer push as hard and as a result I measured lower output. This is why they completely redesigned the springs for these new lights. Said it will perform much better both electrically and mechanically. It should also have more room for longer cells.
Thank you very much for this info, it’s very helpful.
And thank you SKV89, as I understand what you mean about this round of lights being more refined. That instill some confidence, so does all of the positive things about the owner you have mentioned, thank you!
This is good insight, thanks SKV89. I went ahead and ordered the CULNM1.TG version in ‘Desert Yellow’ and am looking forward to seeing how it performs. I see FF put up a new video on YT a couple of days ago, demonstrating this version. I bought the K1 when Hank was still using the CSLNM1.TG
Also precured a good number of CULNM1.TG emitters from AE and one has already been put in an FW1A, but still have work to do to adjust the gasket thickness. I doubt it will stay in the light for long since it’s not too good at handling the heat.
News of FF sourcing this high bin has raised the question of the bin rating of the AE ones.I am not to optimistic about that.
Miguel, I tried to contact FF via their contact page. It is not functioning… Wanted to ask same question, how long before the new lights are available?
E12R :
——First 40pcs E12R nichia (Around 20th December) ,6500Lms , CRI98, Highest CRI98 rosy color
—- SST20 6500K / 5000K (Around 25th) , Max 9800 Lumens , Tint is a bit green on Low modes
——XPL2 HD CW 6500K version (Around 25th December) , Note: XPL2 HD is very cool white and tint is a bit bluish on Turbo
—-Sumsung LH351D W2 CRI80 5700K (Around 25th December) , Brightness 1000 Lumens , CRI80
—-Sumsung LH351D CRI90 4000K (Around 25th December) , Brightness 7800 Lumens , CRI90
NOV-MU
—-Nichia E21A SM455 4500K R9080 CRI99 5200Lumens (Around 20th)
—-Nicha E21A Sm2050 2000K R9050 CRI95 (after Xmas) , 3800 Lumens, This emitter has very rosy tint, but emitter supply from Japan has some delay.
I took it as 10,000 lumens, with high quality “Sumsung” LEDs. I am just joking, I certainly can’t speak two languages so what do I know of phonetics and honestly Jack can write English better than I can usually. I am thrilled with the new models and can’t wait to test them all out, I have a few of each model coming since they are a combination of high CRI, awesome bins, and USB-C, an award winning combination in my mind.
From Jack: Firefies pogo programmer key will be available soon, This pogo key is compatible with USBASP, and only supports to reflash drivers on new fireflies flashlights. It supports common USBASP and 10-Pin cable.
Hank has had issues with this as well, and more recently. I have a D4V2 with E21A emitters that can crush almost any size 18650 unprotected cell because he used a brass button in combination with a spring on the positive battery terminal. I am not sure how many were sent out that way, but Hank has tons of experience and sometimes mistakes just happen. At least with Hank or Jack if you have an issue they will either repair it or offer/sell you parts to fix it yourself. Some companies like Astrolux won’t sell you individual parts like drivers or honor any warranty, leaving it up to you to source parts or throw it in the trash, and that is unacceptable. Jack has always helped me buy replacement parts, and his customer service always has been reasonable.
