Glad it helped
The quads are larger than the triples, unless the flashlights are highly moded to be narrower. Vinh (Skylumen) made a FW3A fit a quad MCPCB and Optic, but he had to “trim” that to fit well. Using normal optics and MCPCBs, the quads will always be larger.
You can check if the bezels of the Emisar D4V2 or KR4 fit, but those will be probably larger and the thread will be even less similar. But maybe someone can help on that
Cool MascaratumB!
I think I’m gonna try that switch mod.
Last night my 14500 battery suddenly depleted.
Quick voltage check using Nitecore F1 charger shows only 2 volts but my VC2 charger says the battery is full
It makes my FWAA is practically not in use until I get a new battery. It’s not easy to find good one here locally.
Ha! This is a very nice find, I wonder how come I've skipped over it until now..
Anyways, I believe the proper fit should be for the tail switch versions, MT20C or MT10C:
Also, while not a straight fit, I've found that a C8 Mini version (Jaxman in this case - not all C8 minis might fit tho I suppose) with the need of a conductive ring/spacer would be a better proportioned fit with its thinner tube and tailcap.
I’m not sure how common these tins are around the world, but the plastic lid of my Lavazza coffee tins are a perfect fit as a protective cap for the Wildtrail WT90. But although it clamps, I will use two bits of cellotape as well because the WT90 bezel has no rim around the outside of the bezel for a firm clamping action, like the coffee tin.
