Thanks Taskulamppu, I've added it to the list
:BEER:
- SAM -
:BEER:
- SAM -
I've tried to determine some Anduril firmware versions (or a guess) of a few Anduril flashlights that I've checked out:
Meote FM1 copper = has version check: 2019-09-28
FT03-Mini = has version-check: 2019-09-28
Sofirn SP36 BLF Anduril, Sofirn IF25A, Astrolux EC01, Astrolux EC03
= I think it has been determined by TK that they run the same old version of Anduril:
all of them do not have the 2-level brightness in lockout mode, nor manual memory mode. So firmware has to be earlier than 2019-05-22 (this firmware date added the 2-level lockout). The button blinking is a "breathing" pattern, which is added in Anduirl firmware date 2018-12-14. So the firmware used by these flashlights would be somewhere between 2018-12-14 and 2019-05-22.
Astrolux HL01 = has 'factory reset' function, but no 'version-check' function [between 2019-06-27 & 2019-09-24]
Astrolux FT03S = has 'factory reset' function, but no 'version-check' function [between 2019-06-27 & 2019-09-24]
('factory reset' added in firmware version 2019-06-27, 'version-check' added in 2019-09-24)
which would mean these 2 flashlights have Anduril firmware version dated between 2019-06-27 and 2019-09-24
Haikelite HK04
- Anduril version 2019-06-02 (has manual memory via 5H); but no factory-reset function
(firmware 2019-06-02 added 'manual memory' function; 'factory reset' added in 2019-06-27)
I tried to check some functions of Anduril (in the Anduril repository change log) to help determine which functions added in which date (for Anduril versions that didn't have the 'version-check' function yet)
2018-12-14: fancy aux-LED (button switch LED) blinking mode (like heartbeat breathing effect) on BLF Q8/SP36
2019-05-22: 2-level lockout brightness (4-clicks); momentary strobe mode possible (go to strobe modes before going to momentary mode)
2019-06-02: manual memory option (5H) ; button-release time-out is a bit faster
2019-06-27: factory reset function (hold button while tightening the tailcap)
2019-09-24: version-check function (15C) ; safety ramp-down if button held too long
Sofirn SC31 Pro with Anduril is not in the list yet. It has 2 mode lockout and 15C version check. Not sure how to tell which version it has exactly.
Sofirn SC31 Pro = Anduril version 2020-03-18 (based on 15-clicks version check)
new batch Astrolux EC03 = Anduril version 2020-03-18 (based on 15-clicks version check)
So ... what did I miss? Any new flashlights to add?
- Sam -
Noctigon K9.3, Astrolux EA01, new FireFlies lights with 2.0
Since I don't see any "Anduril 2" category on the initial post of this thread (list of lights classified by UI), I'm wondering: are there any lights currently sold with Anduril 2 already installed?
Lumintop FWAA.
Thanks BOO5TED.
Strangely it is not on lumintop.com, but I found it on lumintoplighting.com.
Two different websites for the same company ?
Apart from this one, no other lights (in particular the 18650 versions of the FW) ship with Anduril 2 yet?
Also the Fireflies E07X Pro is sold with Anduril 2 installed.
Don’t forget
abouthttps://www.lumintoponline.com/ . Not sure why they need three different sites for the same company but whatever.
AFAIK the FW3A (which would be my first choice) cannot easily be updated to Anduril 2.
What about the FWAA, any easily accessible pins for a future UI upgrade (Anduril 2.x, etc.)?
Hi All
I'll try to update the list the following weeks ...
It would make it much less difficult for me to maintain this list if the community could mention new Anduril (v1 & v2) flashlights once and a while …
- SAM -
Subject to correction, some updates concerning Andúril 2 on upcoming Sofirn flashlights:
The new JETBEAM EC26 seems to have Anduril, not sure 1 or 2
Interesting find.
http://jetbeamlight.com/products_show327.html
The light seems to look like an EDC18, except it uses quad XPL-Hi (instead of the EDC18’s triple LED).
Product description does not mention “Anduril”, but the listed modes (including ‘storm’, ‘candle’, ‘beacon’, ‘sunset’, even ‘muggle’ mode) and usage operation (how to factory reset), matches that of Anduril.
Must be Jetbeam’s first Anduril-based flashlight, if it really does use Anduril.
freeme's group buy thread on the EC26: https://budgetlightforum.com/t/-/66621. Didn't know JETBeam was into cloning...
Jetbeam EC26 comes with Anduril 1, firmware version 2020-03-18
Lumintop FWAA comes with Anduril 2, firmware version 2020-09-27, model code ‘312’
spotted a new Lumintop HL3A that now comes with Anduril 2, firmware version 2021-01-25, model code ‘322’
I just found out that Wurkkos’s TS30S and TS21 run Anduril. Any other Wurkkos lights using Anduril?
I believe those are the only Wurkkos models for now. TS21 is a new Wurkkos model.
Many Wurkkos lights are “diving” lights, not that suitable to use Anduril (eg. DL70, DL40, DL30, WK20, WK20S, DL07, DL10R)
The others are somewhat special multi-LED lights (eg. WK30 and HD20)
The other Wurkkos lights are smaller AAA lights (WK01, WK02).
They probably could have used Anduril on the TS30, but guess they decided to use their own proprietary firmware for this model.
