Little upgrade. Tir is more sutable for me:
Compare with anothe one:
Hmm… Something wrong with photo:
Yup! I just got my Yajiamei shipment in a couple weeks ago and swapped mine for a pebbled TIR as well. Makes it much better for up-close tasks.
I needed to be careful about the height. I first tried without the reflector centering gasket and there wasn’t enough height to push the MCPCB against the shelf. It must have been floating a little because the LED started to turn blue and the bottom of the TIR started to melt. I stuck the gasket in there to add some height and it’s worked well since.
Hey Gchart, what TIR worked the best for you ?
In addition to updating all My H1’s with your drop-in MCU’s I changed the locator LED to blue, added a Sofirn Gummy and made up a custom camo headband. Ramping OS with a locator LED makes this light shine IMHO
Glad you’re liking yours! I get a lot of use out of mine.
I picked up a few different sizes, but I think I ended up with the 60° version of these for up close work
I’m a big fan of convoy and the H1 looks great, but I wish they made it lighter since that is very important for a headlamp.
My H03 weighs 44g, and I can feel the extra weight of my 56g wowtac A2, so for me that 70g of the H1 is unfortunately enough to keep me from getting it.
Gchart, that stock lumen vs time graph doesn’t look very regulated. Is that just heat and a high Vf LED that makes it look sort of direct drivish?
I agree the graph kinda looks that way, but it’s using the 7138 linear regulator (a cousin of the 7135).
I haven’t weighed it, but I think the updated version of the H1 trimmed down the weight a little bit. I agree of headlamps it might be a bit heavy. I’ve worn it for a few hours at a time before and it is a bit heavy but that weight also helps provide extra thermal mass. Just depends on your needs in a headlamp.
I don’t really notice a difference in weight between the H2 and my lightest light, the Zerbralight H600. I just weighed them with the same battery and stock headbands and came out at 150g vs 120g, so definitely a difference but the better headband seems to counter this extra weight somewhat. Sofirn SP 40 wins for heaviest 18650 light at 155g.
It’s really the headlamp weight by itself (without strap) that matters more for comfort/bouncing because the headlamp is cantilevered out from your head some while the strap itself is right on your head and distributed.
But you’re right, the strap quality can make a difference, and for a lot of uses 20g extra is not going to be a deal breaker. But weight is more important for headlamps than your average flashlight.
Does anyone know how to change ramp time? It’s too fast, going from 0 to 70-80% in ~2 seconds, my friend just can’t pick the right low level. I would like to make the speed of passing the brightness from 0 to 100% within 5-6 seconds
From off - 6 clicks to 4 step mode?
Here are the control settings, ramping is by default
I wonder if this behavior of the flashlight is somehow corrected physically or does the processor need to be reflashed?
As stated in post #5, modifying the driver for alternative firmware is likely the only option. IMO, it’s just a horrible driver/ UI. I’m not an engineer versed in microelectronics, nor interested in “modding”, so if it doesn’t run right out of the box, it becomes a paper weight. Unfortunately this is the same driver in my Pioneman K36. Great light design handicapped by a lousy driver. I won’t buy another light with it installed.
Again, just my opinion.
I understand, thank you, then to him have to put up with and use 4 fixed levels.
thanks for the info!
is it possible to make the output to LED to ~4A?
if yes, do you know to which resistors values should I change?
is it possible to tweak the light pattern on the Convoy H1 / H2 ?
The light has an okay price and suits my needs, but I can’t really tell what beam angle I need. In any case, I want a fairly even light spread without hotspot. The light is for working on things, sitting on its tailstand, at a distance of 1 or 2 meters.
I’ve swapped optics on mine, using a wide-beam honeycomb lens. An easier route might be to add DC-Fix or something like that, though the effect will be less pronounced.
okay, thanks, I looked up what film it is.
How can I tell which lens is compatible?
edit: these types? https://www.reddit.com/r/flashlight/comments/5pc9ct/convoy_s2_tir_lens_1015254560strip
Not those…those are the usual 20mm for the S2+ and such. He started selling a smaller 17mm for the H1 with a square mount for 5050 emitters (XML, SST40, etc). Lots of options now. If you want to try some different angles he may be willing to mix and match the 5pc order if you send him a message (sometimes he does, sometimes he doesn’t).
https://www.aliexpress.us/item/3256803132006913.html
There’s probably some at the popular Yajiamei Optics Store, too…they sell them with and without the holders so be sure to look at the dimensions (like a lot of 17mm listings are actually 15mm optics). It’s a good shop but the shipping these days makes it less of a bargain. https://www.aliexpress.com/store/1100564393
If you have the OP lens, DC fix works wonders on the convoy headlamps. Especially the H3. It’s so ring-y. The h3 feels kinda dumb, heavy 21700 for only 1 emitter, but then you put a little dime sized thing of DC fix on it and boom, it’s instantly amazing. And now that extra 3amps and the runtime from the 21700 makes sense, shine through the DC fix. Now you don’t have to worry about the DC fix soaking up too much output and the light being too dim, DC fix doesn’t get in the way of anything. And any traces of rings are completely gone
I bought the H2 by accident, instead of the H1… and it has a clear leans instead of TIR. And Convoy doesn’t want to sell me a mixed set of TIR lenses.
