New 5-digit power supply RD6006P is released 60V 6A
RD6006P customer feedback
This S400 shell is great, about 1.5 mm thick. No bending traces were found in the assembly. There is still room at the top of the 350w switching power supply, and it can be used for battery charging
www.aliexpress.com/item/1005002185722889.html
my first DC power supply, good
Order received. SUPER!!! Thank you very much. Very pleased with the purchase
Excellent for accurancy
for RD6006P, some customers have already reveived the devices and after test, they give us positive feedback. It seems that 5-digit display, higher accurancy and lower ripple is more important for some customers.
RD6006P customer review
Good precision in CV mode, low ripple. Another thing from this seller and it works fine. I recommend!
great seller (thank you)
https://www.aliexpress.com/item/1005002185722889.html
RD6006P feedback
It came packaged well, in foam plastic, it was not crushed at the post office. Collected for two hours. Who comes to visit.
RD6006PW feedback
The efficiency has slightly decreased, but the ripple level has become low for a switching power supply. I plan to prepare a detailed review of this converter with tests. You can find it on my Youtube channel - MrDemalit.
When you order our products, you can check the option title and picture to see what you can get.
And if you still have questions, you can check the description, there are more information.
Our case has necessary components like screws and cables for internal connection.
RD6006PW feedback
A smart device, my dream has come true) I recommend this laboratory!
Exactly as ordered. Quick delivery to NL. Well packed.
RD6006P review
Really great kit. I bought RD6006p Set and now have a power supply almost as good as the >$1000 supplies I use at work. All parts supplied along with a link to the assembly process.
RD6006PW feedback
Wow! What a great unit. Very simple to install, and perfectly calibrated. Even the battery charging option has proved useful. The wifi option works well with the app, but it would be so much better if it worked with secured wifi networks, not just open ones
looks good, good accuracy
RD6006PW feedback
nice device
RD6006PW feedback
The thing is top, it works like a clock, everything is as in the description.
RD6006PW feedback
very happy and very fast !
https://aliexpress.com/item/1005002185722889.html
These just keep tempting me… If I am looking at it right, with wifi and the dedicated PSU and case… $150.50 US + shipping? I have an existing 54vDC PSU of the correct form factor that I could use… That makes it more tempting.
you mean RD6006P or other version, our RD series power supply input voltage range is 6-70V, 54V is ok
