The tubes are sold out.
I assume it is the low voltage protection set for li-ions kicking in, and that could imply that you can not use part of the energy of a LiFePo battery because the flashlight shuts down halfway the discharge.
It’s back on deal on Vipon $27.97
Good day friends, how can I see if it is an aluminum or copper MCPCB? And how can I open the GT Nano?
[img]https://i.imgur.com/9nnuJQf.jpg[/img]
My recently bought US Amazon Nano:
Head opened easily, by hand. Was hard to see the copper looking straight down, so I de-soldered for a better look. Good idea anyway to check the mount and replace the thermal grease.
Poor reflow, led not flat on the board, you can even look under the central pad, makes you wonder if it has enough solder. Redo it just because?
This was mine (I swapped in the sliced SST-20), it looks like it is seated better but on one side you can look under the central pad just like yours with no solder in sight. Makes you wonder if that is why people report purple running leds with the Nano.
Probably should have reflowed it. They never sand the MCPCB smooth like I do and better to know it's got a quality grease like MX4
Received my brass nano with the aluminium 10440 tube from lumintop lighting. Customer service was really good when asking questions about the product and they were quick to switch my original order from an aluminium nano to a brass nano after learning about the 2mm mcpcbs in the newer lights.
Will pick up a brass 10440 tube when they are available along with an aluminium nano when a batch with 2mm pcbs is made, but for now have a bit of a frankenlight.
Even with all the reviews/videos I’ve seen, its pretty shocking seeing so much light coming from something so small!
Cool. Thanks for the update. Looks like a hoot!!
xylnas, congrats on your Nano, and thanks for posting pics
FWIW
It is a common misconception to think that Brass has better heat conductivity than Aluminium. In reality Brass is Worse than Aluminium for heat conductivity.
The alloy brass only has about ½ the thermal conductivity compared to aluminum
imo, the reason some of the Nanos have a problem overheating the LED is because the reflow has an airgap under it, (and I think some people try to use Turbo, too much, by firing it over and over, which overheats the light)
I edited Toms photo to add arrow and text, also see post 727.
imo, the solution is to redo the reflow, properly.
They seem to have come back into stock today showing 36 available.
Thanks!
Interesting, I have always just assumed that due to the copper content that brass would be a better thermal conductor. Will have to take it into consideration in the future, although I am assuming that due to the air gap between the pcb and the body of the light (rather than some form of heatsink) that this will have a relatively small impact on actual useful heat dissipation in relation to running of a torch?
I received the 10440 tube today from lumintoplighting.com. My Nano is complete now:
1) it has a led and a beam that I like and find more useful than the stock led, but at the cost of throw. See What did you mod today? - #9801 by djozz
2) the 10440 (Vapcell) gets me way more runtime and 60% more output (390lm at start and 320lm at 30 seconds) than the silly stock 10180 (210 lm at 5 seconds). The low battery warning+stepdown after 10 seconds on a full battery that I got with the 10180 has stopped too now.
Edit: measured throw with Vapcell 10440 at 30 seconds: 11.3 kcd, which is a bit more than 7kcd that I measured with the 10180 cell, but nowhere near the 21kcd that the stock led produced. Nice tint comes at a price…
3) it looks sóóó much better with a real battery tube.
will the nano copper get battery tube also ?
for a second i thought why is the nano so big in that picture? didnt realized it was the bigger brother lol…
Amazing photo djozz.
Agree
Tnx
Another pic, line-up with some AAA classics
Looking at that pic I so with that someone released DQG Tiny with a modern LED and UI…
That DQG is wonderful, even the UI is still fine for me, but swapping the led is risky and a major pain, I ruined a Tiny many years ago while trying to swap the led and left this one stock (70CRI X-G2) sofar.
So, is lumintoplighting.com the best option to get the whole GT Nano? With the 10440 tube!
djozz, that photo is…monstruously beautiful
it is the only place that shows the 10440 tube for sale (3 left)
even though it is not available on their Nano page
good luck!
