1. Does the USB-C port charge with a USB-C to USB-C cable? It can be charge with that, but it will come with USB-C cable.
2. Can the USB-C port be used as a power bank for your phone? Not in this one, we try to make it simpler, to bring the price down, for power bank you may consider Wurkkos HD20.
3. Is there Anti-Reflective coating on the lens in front of the triple-optic? Yes, to protect the optic.
4. Are there pins/pads available so that the Anduril UI can be easily updated? We will leave the interface accessable, so you guys can update the UI according to your taste.
Lanyard hold in the tailcap, same as HD20. If you use Anduril UI, then you an set it on standby led. Regards CRI, you can choose according to your taste.
The design isn’t finished it seems, but what do you expect will the weight with battery but without clip approximately be?
I’m curious as the IF25A with 4x SST20 is too heavy (ca. 166g with battery) for me in daily use, I prefer to use the FC11 though the SST20 4000K has a nicer light colour than the LH351D.
I prefer the UI of the FC11 to Anduril btw. With the IF25A I get too often into stepped ramping or other states that I didn’t want, I will make a general suggestion of this in another post of a different UI that I’m working on which largely avoids such issues.
The programming interface should be accessible so with this light it would be possible to flash Anduril 2 or other firmware I might do that because the only thing I miss in the FC11 UI is a battery voltage check so I guess Anduril 2 will do just fine. I too get sometimes stuck in settings with Anduril, even though I know the presses sometimes I miss a click and stuff…
